Thread Number: 52379
Speed Queen mixing valve specs |
Post# 746938   4/1/2014 at 21:25 (3,676 days old) by washman (o)   |   | |
for the AWN series. Now I know why "warm" is actually "cool". Mixing Valve Flow Rates (Gallons per Minute) Hot Cold Warm 35 psi 2.4 4.5 7.15 55 psi 3.5 6.2 9.2 (40% Hot) |
Post# 746958 , Reply# 1   4/1/2014 at 22:24 (3,676 days old) by dnastrau (Lords Valley, PA)   |   | |
I wonder if the valve simply has a restrictor on the hot side that could be removed or drilled out? |
Post# 747015 , Reply# 2   4/2/2014 at 06:44 (3,676 days old) by Yogitunes (New Jersey)   |   | |
Post# 747034 , Reply# 3   4/2/2014 at 09:05 (3,675 days old) by roscoe62 (Canada)   |   | |
I think I saw you do this before, where is this valve and what size bit did you use to get more hot water? I have to buy a new washer and may have to do the same thing. Thanks for your help. |
Post# 747035 , Reply# 4   4/2/2014 at 09:10 (3,675 days old) by mrb627 (Buford, GA)   |   | |
Post# 747039 , Reply# 5   4/2/2014 at 09:36 (3,675 days old) by roscoe62 (Canada)   |   | |
What would that do to the rinse, just take longer to fill? |
Post# 747060 , Reply# 6   4/2/2014 at 11:09 (3,675 days old) by mrb627 (Buford, GA)   |   | |
Post# 747089 , Reply# 7   4/2/2014 at 12:54 (3,675 days old) by Yogitunes (New Jersey)   |   | |
I just took both screens out, and tried several drill bits until I found one that matched the COLD side...and then carefully drilled the HOT side....making them both equal...remember to put the screens back in place...I never took the valve out of the machine to do this.....
now I am curious if I could have went a little larger and increased flow volume to fill faster.... |
Post# 747109 , Reply# 8   4/2/2014 at 15:14 (3,675 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Post# 747126 , Reply# 9   4/2/2014 at 16:35 (3,675 days old) by Yogitunes (New Jersey)   |   | |
Post# 747127 , Reply# 10   4/2/2014 at 16:45 (3,675 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
I did this a year ago on the Whirlpool we have at work for washing shop towels.
See see below......
Kevin
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?45957
