Thread Number: 52524
(Older ) washer and dryer works great - $100 (Nashville) |
Post# 747985   4/6/2014 at 00:39 (3,672 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Posted a Day ago:
"Whirlpool washer and dryer. Older model but works great and not used much at all. $100 for both. I also have another set that is a newer model. Both sets must go today. Any reasonable offer will be accepted." CLICK HERE TO GO TO ovrphil's LINK on Nashville Craigslist |
Post# 748039 , Reply# 1   4/6/2014 at 08:27 (3,672 days old) by appnut (TX)   |   | |
To mee the cycle dial is out of sequence. Soak/pre-soak follow after the regular/heavy cycle as does Permanent Press after knits/delicate. Most Whirlpools I've seen over the years had soak/prewash or super wash and then followed with normal or regular/heavy. Now I will admit I vaguely remember some gentle or knits/delicate preceding Permanent Press. But to me, Kenmore always had it in proper order. Pre-wash or soak, then Normal, then Permanent Press, and then Knits/Delicate. Most intense first and gentlest last as you went around the circle;.
