Thread Number: 52629
Maytag A106 problems |
Post# 748982 , Reply# 3   4/9/2014 at 20:13 (3,668 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
....The damper pads could possibly stand to be replaced. These are three polypropylene pads that are under the spin base. They are glued to the baseplate of the washer (the gray metal "floor" of the washer), and they are lubricated with a substance called Polylube. The spin base rotates on the three pads.
A set of damper pads, complete with instructions and Polylube, is less than $20. It's a DIY repair if you're handy. Worn damper pads squeal and squeak, and the noise is worse in cold weather. The noise is most pronounced in the spin cycle. Search here on "maytag damper pads" if you want to know more. |
Post# 748991 , Reply# 4   4/9/2014 at 21:32 (3,667 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Carly, you have gotten great use out of this washer, and your decision to buy a new Speed Queen is a good one. the squealing noise when the machine is a dry brake, this is fairly easy to fix, the excessive vibration during spin is likely bad damper pads. Bad damper pads is usually the end of the line for MT washers, while the pads are cheap putting them in is a MAJOR repair AND if the machine has been used with bad pads you also need to replace the aluminum damper assembly and this requires complete dissemblely of almost the entire machine. As a repair professional we NEVER repair MTs when they have this problem.
The noises you are hearing are not bad belts, loose supports or a bad clutch, your MT washer does not have a clutch, and if the tub supports were loose it would be leaking water like a sieve. The good news is that you can keep using this washer as long as it is getting the job done, and the even better news is a new SQ washer used under the same conditions will wash far more clothing and last longer than even this MT did. John L. |
