Thread Number: 52657
FREE! GE slide-in range (yellow) - Florence, MA |
Post# 749279   4/11/2014 at 09:45 (3,666 days old) by turquoisedude (.)   |   | |
The ad states that the oven control is off... Not sure if that could simply need an adjustment... Neat model from the early 60s, though!
CLICK HERE TO GO TO turquoisedude's LINK on Westernmass Craigslist |
Post# 749402 , Reply# 1   4/11/2014 at 21:45 (3,666 days old) by bluejay (Havre de Grace, MD)   |   | |
Post# 749403 , Reply# 2   4/11/2014 at 21:50 (3,666 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 749405 , Reply# 3   4/11/2014 at 22:01 (3,666 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Usually the oven temp knob has an adjustment available on the back of the knob - you loosen a screw and move the shaft a bit, then re-tighten the screw. Some knobs are even marked with a scale and info on how much adjustment you get with each scale marking.
All it is, is moving the skirt of the knob in relation to the shaft, so that the temp markings on the skirt match up to the actual temp of the oven. Here's a pic; while the back of a given oven temp knob may not look exactly like this, there will usually be something similar. |
Post# 749434 , Reply# 4   4/12/2014 at 02:33 (3,666 days old) by laundromat (Hilo, Hawaii)   |   | |
