Thread Number: 52763
Hobart WM-1D dishwasher |
Post# 750755 , Reply# 2   4/17/2014 at 18:48 (3,632 days old) by mikeCL ()   |   | |
Thanks Steve for the help, I was fearing no one knew anything about this :) Now that my internet speeds are working this should be more help |
Post# 750756 , Reply# 3   4/17/2014 at 18:50 (3,632 days old) by mikeCL ()   |   | |
Oh I forgot to say I haven't tried to put water in it manually yet but I will try again tonight. |
Post# 750772 , Reply# 6   4/17/2014 at 19:59 (3,632 days old) by mikecl ()   |   | |
Does the wash arm just pull right up? Good to know it uses parts from another model, that's a relief. |
Post# 750777 , Reply# 8   4/17/2014 at 20:24 (3,632 days old) by mikecl ()   |   | |
OK got the wash arm off but the motor is locked tight. |
Post# 750785 , Reply# 9   4/17/2014 at 20:49 (3,632 days old) by mikecl ()   |   | |
Not so good news is the drain hose that connects to the drain line snapped the connection looks like corrosion. |
Post# 750794 , Reply# 10   4/17/2014 at 21:22 (3,632 days old) by stevet (West Melbourne, FL)   |   | |
Pics of what and where it broke? Start l,ooking for a kd15/16/17 motor or pump. I bet you will find one here. |
Post# 750799 , Reply# 11   4/17/2014 at 21:38 (3,632 days old) by mikecl ()   |   | |
I hope this works I'm not at home. |
Post# 751297 , Reply# 16   4/19/2014 at 19:13 (3,630 days old) by mikecl ()   |   | |
Steve here are some pictures I took yesterday. |
Post# 751298 , Reply# 17   4/19/2014 at 19:17 (3,630 days old) by mikecl ()   |   | |
The black hose is from the booster pressure relief valve. Sorry The picture got rotated sideways |
Post# 751855 , Reply# 18   4/22/2014 at 07:28 (3,628 days old) by mikecl ()   |   | |
Will try and start unbolting the parts to get the motor out. Meanwhile try and figure out the water flow. |
Post# 751923 , Reply# 19   4/22/2014 at 13:24 (3,627 days old) by mikecl ()   |   | |
Around 3 min you see black water come from the inlet. Water will always fill inside the DW unless water is turned off.. Can't find booster water valve yet.. Hobart dishwasher: CLICK HERE TO GO TO mikecl's LINK |
Post# 752044 , Reply# 22   4/22/2014 at 22:50 (3,627 days old) by mikeCL ()   |   | |
Ok here are the pictures |
Post# 752045 , Reply# 23   4/22/2014 at 22:51 (3,627 days old) by mikeCL ()   |   | |
And one more |
Post# 753033 , Reply# 26   4/27/2014 at 01:30 (3,623 days old) by mikeCL ()   |   | |
Oh boy.. so I guess me turning on the water valve under the sink.. it now causes a very tiny waterflow stream into the DW now.. so now the DW is always full of water the next day after you drain it.. |
Post# 755791 , Reply# 30   5/8/2014 at 19:45 (3,611 days old) by MIKECL ()   |   | |
Ok I think I will just disconnect from the booster and do it that way.. hopfully will be able to pull it out before I leave. |
Post# 755887 , Reply# 32   5/9/2014 at 09:55 (3,611 days old) by mikecl ()   |   | |
Motor is out! That part was pretty easy |
Post# 755899 , Reply# 33   5/9/2014 at 11:58 (3,610 days old) by stevet (West Melbourne, FL)   |   | |
Who wouldn't want one of these in their kitchen today? A Classic beauty in the best of Hobart tradition. Mike, I emailed you on some of your questions. Steve |
Post# 755914 , Reply# 35   5/9/2014 at 13:55 (3,610 days old) by MIKECL ()   |   | |
Btw Steve are you sugesting I get new solenoid valves instead? |
Post# 756319 , Reply# 39   5/11/2014 at 13:42 (3,608 days old) by mikecl ()   |   | |
Yes I will be getting that motor and will be ordering the drain pump. I don't remember if I sent you the pictures but one line strainer was fully blocked and the other had that black stuff. |
Post# 756324 , Reply# 40   5/11/2014 at 14:19 (3,608 days old) by stevet (West Melbourne, FL)   |   | |
Yes, I got the pictures of the line strainers. I figured it was a non issue as you said you would be ordering the new style valves with the built-in strainers. |
Post# 756344 , Reply# 43   5/11/2014 at 16:25 (3,608 days old) by stevet (West Melbourne, FL)   |   | |
You should be able to make it work just fine and in metal, you won't have to worry about the hi rinse temp water warping it like a pvc fitting. The project is moving along. |
Post# 756689 , Reply# 45   5/13/2014 at 07:24 (3,607 days old) by mikecl ()   |   | |
One question the tailpeice I got has the drain pipe a little bigger so the stock hose won't fit.. My question is the hose to motor will a larger hose be a issue? |
Post# 756802 , Reply# 49   5/13/2014 at 19:25 (3,606 days old) by MIKECL ()   |   | |
Holy cow that hatco temp gauge was a pain to get off.. took lots of heat and PB blaster.. I ordered a replaced guage today.. part of pipe fitting came off due to the forces, but I can fix that. |
Post# 756813 , Reply# 50   5/13/2014 at 20:24 (3,606 days old) by stevet (West Melbourne, FL)   |   | |
Mike, I guess you didn't hear me whenwe talked on the phone the other day.I said that I had a few new spare Hatco gauges and would send you one if you wanted it. Impulse buying is expensive! Can you cancel it? |
Post# 756822 , Reply# 51   5/13/2014 at 21:11 (3,606 days old) by mikecl ()   |   | |
Ah shoot I forgot about that.. I'm afraid it's too late as it shipped already. I think it was around $27 or so |
Post# 756976 , Reply# 52   5/14/2014 at 17:36 (3,605 days old) by mikeCL ()   |   | |
Motor will be in Friday so at least I have a date now! And the shipping for ground with UPS is fast only a day which is nice to know. |
Post# 757346 , Reply# 56   5/16/2014 at 07:33 (3,604 days old) by mitch (Atlanta)   |   | |
Make a powdered product called Zepomatic that seems to be old school. Grainger and other places list it. Most interesting thread--good luck! Mitch CLICK HERE TO GO TO mitch's LINK |
Post# 757361 , Reply# 58   5/16/2014 at 08:35 (3,604 days old) by MIKECL ()   |   | |
Hmm I see a powder zep product on Grainger but it's not the same product number, the only two places I've seen is on a medical supply place. |
Post# 758539 , Reply# 61   5/21/2014 at 05:50 (3,599 days old) by mikecl ()   |   | |
Thanks to Steve for sending me replacement drain pump bolts and a new temp/pressure gauge! I will start putting this stuff in today. |
Post# 758721 , Reply# 65   5/21/2014 at 20:22 (3,598 days old) by mikeCL ()   |   | |
Well since I'm home now I'm just going to use my calipers, if I run into any issues I will let you know. |
Post# 758743 , Reply# 67   5/21/2014 at 21:28 (3,598 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Can y'all help me the the concept of using shims? I realize they are "spacers" of a sort but why not mill the pieces to fit without them? |
Post# 758744 , Reply# 68   5/21/2014 at 21:34 (3,598 days old) by mikeCL ()   |   | |
Correct me if I'm wrong but from what I searched around here it's to deal with the pump pressure and seal when the wash arm is on. Now as to why and not just mill the parts that's a good question. |
Post# 758984 , Reply# 71   5/22/2014 at 19:57 (3,597 days old) by stevet (West Melbourne, FL)   |   | |
Mike, the impellers were molded and smooth. Somthing must have gotten in there and scraped it up. Not to worry. You should have plenty of pressure when it gets put back together. |
Post# 762131 , Reply# 74   6/7/2014 at 18:24 (3,581 days old) by stevet (West Melbourne, FL)   |   | |
I was wondering what happened to you! I figured that you got it all back together and was showing it off to everyone who came into the kitchen! |
Post# 762561 , Reply# 75   6/9/2014 at 18:19 (3,579 days old) by MIKECL ()   |   | |
Hah not yet Steve it's still sitting in my office |
Post# 779423 , Reply# 76   8/25/2014 at 22:47 (3,502 days old) by mikeCL ()   |   | |
Steve do you happen to have the part number for those new valves again? I seem to have misplaced the email which is odd because I don't remember deleting any of it. I've gotta get this dishwasher out of my office space LOL |
Post# 781748 , Reply# 77   9/5/2014 at 20:30 (3,491 days old) by mikeCL ()   |   | |
The valves came in so i'm a bit confused on how the stock setup is so I'm looking at adding about 5 inches of new copper?
Post# 781759 , Reply# 79   9/5/2014 at 21:01 (3,491 days old) by mikeCL ()   |   | |
But I'm still having to get rid of the old Wye strainers I think they are 3/4" but they sit back a ways from where the old asco valves used to be. Hopfully it wont be too much to get the old stuff off |
Post# 782037 , Reply# 82   9/6/2014 at 22:28 (3,490 days old) by MIKECL ()   |   | |
Got the connections made.. good thing the wires themself are labeled F1 & F2 I still need to get a adapter fitting for the drain due to the new Y-pipe drain having a larger opening then the old one that broke. |
