Thread Number: 52819
New never used Vintage 70s/80s General Electric dish washer |
Post# 751373   4/20/2014 at 06:19 (3,652 days old) by chachp (North Little Rock, AR)   |   | |
Condition: Great! This dishwasher has sat in storage for over 3 years so it needs to be cleaned. It has NEVER been used-there is no damage beneath the dust sitting on it. It was originally destined to go overseas but when that fell through it was sent into storage. The self standing wood table top can use light sanding to refresh the finish. The bottom cover is bent in and needs to be fixed.
CLICK HERE TO GO TO chachp's LINK on eBay |
Post# 751425 , Reply# 1   4/20/2014 at 09:56 (3,652 days old) by appnut (TX)   |   | |
Post# 751428 , Reply# 2   4/20/2014 at 10:10 (3,652 days old) by bajaespuma (Connecticut)   |   | |
Post# 751429 , Reply# 3   4/20/2014 at 10:14 (3,652 days old) by turquoisedude (.)   |   | |
Post# 751492 , Reply# 4   4/20/2014 at 17:36 (3,652 days old) by jakeseacrest (Massachusetts)   |   | |
Post# 751507 , Reply# 5   4/20/2014 at 18:59 (3,652 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 751517 , Reply# 7   4/20/2014 at 19:41 (3,651 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 751523 , Reply# 8   4/20/2014 at 20:28 (3,651 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Plastisol was a tub-liner system used by GE for many years. It consists of a vinyl-type plastic bonded to steel. My understanding is that it was not used on Canadian models, but it sure as Hell was used here, for far too long.
The problem with Plastisol is that if there is any tiniest breach in the plastic layer, water gets through to the steel underneath, and pretty soon the plastic layer breaks out in nasty, lumpy patches - the rust forms bubbles underneath the plastic. Eventually, the rust can go all the way through the steel. Plastisol liners were vulnerable to anything that breached the plastic layer - forks and knives poking through the bottom of the silverware basket were a common problem. Even the edges of Plastisol panels had issues - rust often formed at the edges of detergent dispensers, because the coating stopped pretty much at the edge of the hole in the panel where the dispenser was located. The lower edge of door panels and the front lower edge of tubs were other common problem areas. This problem was so widespread that appliance parts places used to carry "repair kits" that consisted of a color-matched epoxy coating. You ground away the bubbled plastic and the rusty area underneath, then applied the coating. It only worked for a little while, just delaying the inevitable. GEs were notorious for this problem for a long time; they eventually went to an all-plastic tub system called PermaTuf to improve their reputation for quality. PermaTuf did solve the problem with GE's liners. My personal memories of trying to keep a GE with a Plastisol liner running are so painful that I would not even begin to consider another machine with one, not even the mintiest MIB find. I know from bitter experience that it wouldn't be minty long. |
Post# 751537 , Reply# 9   4/20/2014 at 21:32 (3,651 days old) by jamiel (Detroit, Michigan and Palm Springs, CA)   |   | |
