Thread Number: 5296
FL on Slabs/Carpets is the best! |
Post# 114003 , Reply# 1   3/8/2006 at 00:52 (6,623 days old) by the7 ()   |   | |
These are the detergent used in my Huebsch FL. Will use double for my Maytag TL. |
Post# 114004 , Reply# 2   3/8/2006 at 00:57 (6,623 days old) by the7 ()   |   | |
Sorry, this is the photo. |
Post# 114016 , Reply# 3   3/8/2006 at 02:07 (6,623 days old) by sudsmaster (SF Bay Area, California)   |   | |
Interesting. By the way, my home has exactly the same vinyl (?) flooring in the family room. It was hidden under disgusting green wall to wall carpeting that I removed when I bought the place. The flooring actually extends from the family room into the kitchen, but the previous owner put down 1/2" particle board and another layer of newer vinyl flooring in the kitchen area. The padding under the carpet in the family room more or less made up the difference, except of course that it had compressed quite a bit over the years. Eventually I will be removing all the flooring in both rooms, and putting down new stuff. I'm leaning towards ceramic or porcelain tile... but vinyl does have its advantages. |
Post# 114209 , Reply# 5   3/9/2006 at 09:37 (6,622 days old) by frigilux (The Minnesota Prairie)   |   | |
Post# 114402 , Reply# 7   3/10/2006 at 10:56 (6,621 days old) by frigilux (The Minnesota Prairie)   |   | |
I don't know, the7..... Here's how it plays out in my tiny fevered mind's scenario: The washer walks off it's blocks. The load is wildly unbalanced and the timer is stuck on a 1200 rpm spin. It begins to hurl itself across the room violently, killing all in its path. After breaking through a wall, it levels the kitchen and its occupants. Eventually, it crashes through a door and wreaks its destructive havoc on the unsuspecting outside world. But if all THAT doesn't happen, then, yes, it's a very practical solution to your problem, LOL! |
Post# 114474 , Reply# 8   3/10/2006 at 18:33 (6,620 days old) by the7 ()   |   | |
Pulse Spin of my FL. This is file over 20M so it may take a bit longer to download. CLICK HERE TO GO TO the7's LINK |
Post# 114475 , Reply# 9   3/10/2006 at 18:34 (6,620 days old) by the7 ()   |   | |
Max Spin of my FL. Also a large file. CLICK HERE TO GO TO the7's LINK |
