Thread Number: 53116
DG808 Ballast and Wiring Console light.. |
Post# 754715   5/3/2014 at 13:51 (3,638 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 754722 , Reply# 1   5/3/2014 at 14:19 (3,638 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Any ballast for a 24" 20 watt fluorescent lamp will work. You will also need an FS-2 fluorescent starter. Both can be had at Home Depot or any hardware store for less than $10.
I've attached the 808 wiring digram which may or not be of help. It will at least give you a way to trace the correct current path from the ballast, starter, tube and to the neutral.
Obviously for your dryer, you would connect the neutral from the tube to the neutral line. I would then piggy-back the hot line from the ballast onto the motor run circuit.
Post# 754744 , Reply# 2   5/3/2014 at 16:01 (3,637 days old) by moparwash (Pittsburgh,PA )   |   | |
