Thread Number: 53400
Ice maker adjustment? |
Post# 757659 , Reply# 2   5/17/2014 at 12:01 (3,631 days old) by mrb627 (Buford, GA)   |   | |
Post# 757693 , Reply# 3   5/17/2014 at 14:08 (3,631 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
After dealing with a few icemakers I have discovered that it is not worth the time or effort dickin' around with an icemaker. Replacements are reasonable and easy to install. |
Post# 757897 , Reply# 4   5/18/2014 at 10:36 (3,630 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 758067 , Reply# 5   5/19/2014 at 05:30 (3,629 days old) by retro-man (- boston,ma)   |   | |
I have replace them on other fridges. Not that big of a job. Guess will go online and see how much they are and order a new one. Thanks all. Jon |
Post# 758302 , Reply# 6   5/20/2014 at 06:40 (3,628 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
If you are getting hollow cubes and fast cycles you are not getting enough water in the IM to fully fill the mold, usually this is caused by a restricted water supply to the refrigerator. A partial fill does not fill the front of the IM where the thromostat is located and the thromostat cools too fast and starts another cycle before the little water that is in the mold is even frozen.
Turn off the water supply and disconnect the water supply tube going to the refrigerator, then get a bucket to put the end of the water line in and turn it on, you should have a very strong flow of water that sprays against the side of the bucket, it it looks more an 80 year old man trying to ... you have a plumbing [ or prostrate ] problem. Beyond a water supply problem, be sure the NEW inlet valve installed is the correct one for this refrigerator, if you are sure it is replace the IM, but I can tell you after fixing THOUSANDS of IMs this problem is seldom an IM fault. |
Post# 758553 , Reply# 8   5/21/2014 at 07:50 (3,627 days old) by lightedcontrols ()   |   | |
...you also might want to check that the water line isn't crimped when the fridge is pushed back into place restricting the water flow. Mark |
Post# 768107 , Reply# 14   7/5/2014 at 03:05 (3,582 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
