Thread Number: 53615
I need hot water! |
Post# 759661 , Reply# 1   5/26/2014 at 14:33 (3,615 days old) by mrb627 (Buford, GA)   |   | |
Post# 759711 , Reply# 7   5/26/2014 at 21:01 (3,615 days old) by logixx (Germany)   |   | |
Can you select one cycle (Quick Wash for hot water), let the machine fill and than change over to another, longer cycle (or will the machine drain)?
How about using Quick Wash with maximum soil and Extra Rinse?
You said, Deep Steam doesn't get much hotter - was that at the start or at the end of the main wash?
The best (as in largest) I could find wash an Asko rated at 2.83 cu.ft., which is .9 cu.ft smaller than your Sammy with temps ranging from cold to 194F.
CLICK HERE TO GO TO logixx's LINK |
Post# 759726 , Reply# 9   5/26/2014 at 23:45 (3,614 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
... that ANY German washer runs on 220V? And the Hertz don't match either. (50 Hertz here vs. 60 Hertz over the pond, I think). I don't know which model you want, but this *could* bring problems. Further, how about parts? If one fails, you have to import it! |
Post# 759734 , Reply# 10   5/27/2014 at 00:49 (3,614 days old) by Supersuds (Knoxville, Tenn.)   |   | |
Bosch stopped making "full-size" washers about three years ago.
CLICK HERE TO GO TO Supersuds's LINK |
Post# 759788 , Reply# 11   5/27/2014 at 11:44 (3,614 days old) by logixx (Germany)   |   | |
