Thread Number: 53902
DE608 Maytag Dryer - afraid I got a dud :( |
Post# 762291 , Reply# 2   6/8/2014 at 15:08 (3,607 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 762303 , Reply# 4   6/8/2014 at 15:56 (3,607 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 762308 , Reply# 5   6/8/2014 at 16:05 (3,607 days old) by CheezCayke ()   |   | |
I don't know much about electrical things so I'll probably ask boneheaded questions. How do I check the voltage? This is a brand new house with a 4 prong outlet, that is 220 isn't it? |
Post# 762311 , Reply# 6   6/8/2014 at 16:15 (3,607 days old) by CheezCayke ()   |   | |
Yes, door is fully closed. |
Post# 762316 , Reply# 7   6/8/2014 at 16:43 (3,607 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Try turning the dial back and forth a few times and try pushing it in at each setting. When working properly, the dial should offer some resistance and "click" into each of the four positions. Also, try gently pushing the dial in as you slowly turn the dial and see if you can find a "sweet spot".
Behind that dial is a 4-button mechanical assembly and a plate with perforations in it (not unlike an old IBM punch card.) Sometimes that plate gets loose or out of adjustment.
The center dial is the spring-loaded start switch and you should be able to depress it between 1/2" and 3/4" at each of the four settings in order to start the dryer, assuming that everything is adjusted properly. |
Post# 762323 , Reply# 10   6/8/2014 at 17:33 (3,607 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 762324 , Reply# 11   6/8/2014 at 17:36 (3,607 days old) by CheezCayke ()   |   | |
The drum does not move easily. I'll check to see if it's the cord tomorrow. Thank you everyone for your help. |
Post# 762721 , Reply# 12   6/10/2014 at 09:58 (3,605 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 776931 , Reply# 13   8/12/2014 at 14:09 (3,542 days old) by hippiedoll ( arizona )   |   | |
