Thread Number: 5392
What's a coaxial transmission? |
Post# 115240   3/14/2006 at 17:04 (6,616 days old) by roto204 (Tucson, AZ)   |   | |
Post# 115326 , Reply# 5   3/15/2006 at 03:41 (6,615 days old) by spinout (Phoenix)   |   | |
Here is the clutch assembly installed into the transmission. Note the large hub on the bottom of the pulley; that hub receives the agitate clutch spring. |
Post# 115327 , Reply# 6   3/15/2006 at 03:44 (6,615 days old) by spinout (Phoenix)   |   | |
Here it is with the agitate clutch spring and hub in place. Spin it in one direction to agitate, the other way for spin. Elegant, isn't it? |
Post# 115424 , Reply# 7   3/15/2006 at 15:27 (6,615 days old) by roto204 (Tucson, AZ)   |   | |
Post# 115452 , Reply# 8   3/15/2006 at 20:22 (6,615 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 115860 , Reply# 12   3/17/2006 at 11:28 (6,613 days old) by spinout (Phoenix)   |   | |
Here is the anti-indexing mechanism I put on the machine: |
Post# 115861 , Reply# 13   3/17/2006 at 11:34 (6,613 days old) by spinout (Phoenix)   |   | |
During agitate, the solenoid is pulled in, extending the pin which engages the notch on the transmission case. |
Post# 115862 , Reply# 14   3/17/2006 at 11:37 (6,613 days old) by spinout (Phoenix)   |   | |
the bottom of the machine |
Post# 115864 , Reply# 15   3/17/2006 at 12:20 (6,613 days old) by unimatic1140 (Minneapolis)   |   | |
