Thread Number: 54003
Load-dependent wash time adjustments on the way out? |
Post# 763422 , Reply# 2   6/13/2014 at 10:20 (3,603 days old) by joe_in_philly (Philadelphia, PA, USA)   |   | |
I don't think US Whirlpool FL washers adjust wash time based on load. My washer adjusts wash time based on soil level selected. Different aspects of the cycle are adjusted based on the size of the load. For example, a large, heavy load will have a slightly different final spin sequence than a smaller, lighter load. Rinse water levels are higher for larger loads.
Post# 763466 , Reply# 3   6/13/2014 at 17:08 (3,602 days old) by logixx (Germany)   |   | |
Mine adjusts time based on absorbency. For the very long cycles, there is an up to 20 minute long phase, during which the washer won't heat and tumbles slowly for the load to absorb water. Time is calculated once that phase is over. The quicker cycles just fill, calculate and heat. Remaining time is also calculated before each rinse fill and the final spin.
Post# 763488 , Reply# 4   6/13/2014 at 19:47 (3,602 days old) by appnut (TX)   |   | |
