Thread Number: 54032
Help Pinpointed Noise on Maytag A806 |
Post# 763786 , Reply# 2   6/15/2014 at 10:31 (3,600 days old) by swestoyz (Cedar Falls, IA)   |   | |
Hey there Floyde,
To be honest what your service guy did was fine. He changed the belts. I wouldn't expect a service guy to clean the pulleys, but more than likely the new drive belt is squealing for a little bit due to some residue on the drive or motor pulley. You can clean the pulleys yourself with steel wool if you are concerned about the squeal, but nothing is going to break if you decide to let it go.
As for the knocking sound you are hearing, the brake package now has some lubrication to aid the shoes for when the machine stops from spin. This is a good thing. The knocking noise you are hearing would be the shoes themselves holding the transmission in place during heavy loads. Again, the noise isn't going to hurt anything. If you want it completely gone then I'd suggest looking into having a new brake package installed, but I've even seen new brake packages do the same.
If you want to ensure that your Maytag lasts for years to come, you may want to consider getting your hands dirty and start learning how to work on these machines. They truly are pretty simple to work on, and there is plenty of service information available on AE.org, and there are tons of threads of folks who have documented their repairs and restorations. I suggest this as you may have a harder time finding service from a 3rd party in the future.
I hope this helps,
Ben |
