Thread Number: 54034
saturday was bendix day |
Post# 763763 , Reply# 1   6/15/2014 at 08:02 (3,595 days old) by keymatic3203 (Cardiff UK)   |   | |
Mains indicator on. I still need to run the hot water pipe work in so it will be fed from bendix taps, I was intending to do this work, but of course a new machine is always more exciting. |
Post# 763764 , Reply# 2   6/15/2014 at 08:04 (3,595 days old) by keymatic3203 (Cardiff UK)   |   | |
Whilst heating. |
Post# 763765 , Reply# 3   6/15/2014 at 08:08 (3,595 days old) by keymatic3203 (Cardiff UK)   |   | |
with replacement door gasket. |
Post# 763766 , Reply# 4   6/15/2014 at 08:09 (3,595 days old) by keymatic3203 (Cardiff UK)   |   | |
both heater and mains indicators lamps on. |
Post# 763767 , Reply# 5   6/15/2014 at 08:13 (3,595 days old) by electron1100 (England)   |   | |
Oh Mat Bendix is the way to go ;-)
again a beautiful machine, and to have it running! gobsmacked! a mechanical marvel indeed............... It seems that Wales is doing well on the Bendix front and the North East with Ricky It just so nice to see these machines coming together and giving pleasure. Proper Job :-) |
Post# 763772 , Reply# 6   6/15/2014 at 08:25 (3,595 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 763773 , Reply# 7   6/15/2014 at 08:46 (3,595 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 763797 , Reply# 8   6/15/2014 at 11:23 (3,595 days old) by fido ()   |   | |
Yes, another lovely old Bendix! Looks to be well made and sturdy. |
Post# 763800 , Reply# 9   6/15/2014 at 12:32 (3,595 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 763813 , Reply# 11   6/15/2014 at 13:54 (3,595 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 763828 , Reply# 12   6/15/2014 at 16:30 (3,595 days old) by ricky5050 (Durham Britain)   |   | |
I hoped it had found a good home , I have a workshop manual ( if you don't I think you might , I'm not sure who has what here,) I know what you mean regarding the dryer fan it makes a racket during washing , apparently US models had a third solenoid to switch fan on and off when needed.
One thing they don't really work off " cold " water , if you select 3, 4 a warm wash they fill with a mixture of hot and cold so cold water only will be at the temp of incoming water, the heater doesn't kick in at all. If cold only fill 1,2 ie very hot or hot will only heat to a certain temp, water has to be a certain temp or thermostat switches off early, so will result in a lower temp. No prob for quick play, but it does require hot water. In a way if "free" hot water can be sought theses are very ecological as it only uses electric to boost temp. Mine has developed a thermostat problem, number 2 should be about 65.c but now goes on to heat to near boiling. To get a 40.c I run hot tap ( from combi boiler ) and let it fill on a number 2 , once full press 4 and it washes at 40.c To get 60 I do same but press 2 and then press 4 once it's heated to what I feel like 60 is. I tend to press 4 as it does cold rinses , then press 1,2,3 to get longer spin. This is my only washer so some may think a faf but still love it. They are solid machines well done! Richard
Post# 764033 , Reply# 14   6/16/2014 at 16:25 (3,594 days old) by hotpoint95622 (Powys)   |   | |
Post# 764306 , Reply# 16   6/18/2014 at 02:50 (3,592 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 764309 , Reply# 17   6/18/2014 at 03:35 (3,592 days old) by keymatic3203 (Cardiff UK)   |   | |
Al, sold on ebay, he got it some months ago, installed and enjoyed it, but once this bendix and the gas range came along a few things had to be moved on. Mathew |
Post# 764393 , Reply# 18   6/18/2014 at 13:45 (3,592 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
