Thread Number: 54037
What is your favroite vintage washer that you would use for doing your laundry? |
Post# 763819   6/15/2014 at 15:07 (3,596 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Hello to all if you have any fav vintage washers in your collection witch would you use on regular basis?
Me it would be these models if i had a collection a few pictures just to list a few models |
Post# 763913 , Reply# 1   6/16/2014 at 01:49 (3,595 days old) by tolivac (greenville nc)   |   | |
Difficult question for me-its also like what is my favorite vintage vacuum cleaner.Sadly no room at my place for vintage washers-except just a few.Presently WP-KN BD and a Hotpoint-has rim flow and the ramp blade agitator. BOL Builders model. |
Post# 763919 , Reply# 2   6/16/2014 at 03:56 (3,595 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
I've had SF Westinghouse, large and small tub Maytags, WP BDs, a Filterflo here and there, a Frigidaire and a Panasonic twintub, all vintage and all worked perfectly well. None was a dog for wash/rinse ability. The Panasonic spun best by twice. The Westy and Tags were easiest to work on for routine upkeep like belts, the WP was a curse (literally), changed the pump coupling on a FF without too much gnashing, the Panasonic needed no repairs. The Panasonic also had a unique bottom-offset washplate that created VERY active turnover without much knotting despite non-reversing.
Current machine is Panda (China) twintub. Best solution for the space and laundry volume I have. I'd rather have the Panasonic back but that's impossible. The latemodel Maytag coinop TLs and FL downstairs are inflexible to the point of unusable. No options, not even pause/soak. The only thing they do right is fill adequately. Tough laundry would require 3 cycles to do right and rinse well. |
Post# 763970 , Reply# 4   6/16/2014 at 10:30 (3,595 days old) by electron1100 (England)   |   | |
