Thread Number: 543
Help needed w/ DD Kenmore |
Post# 49430 , Reply# 1   11/18/2004 at 10:06 (7,092 days old) by CleanteamofNY ((Monroe, New York)   |   | |
It could be one of two problems with these machines; 1. Could be broken or worn suspension springs. 2. Suspension plate pads needs to be replaced. You'll need to get a manual to help make this kind of repair. "Do it yourself repair manual for Kenmore Automatic washers" {Direct Drive} It can be found on ebay from time to time or from your Sears repair/parts centers.... Good luck! |
Post# 49496 , Reply# 2   11/19/2004 at 09:00 (7,091 days old) by HQOTS ()   |   | |
The brake shoes are too tight. You can either change the spring in the brake assy or squirt some oil up there. |
Post# 50127 , Reply# 3   11/29/2004 at 17:55 (7,080 days old) by maytagluver ()   |   | |
I gave it a shot of WD-45, lo & behold, works like a champ!!!! Thanks for the info Al :) |
