Thread Number: 54366
stacking different washer models is it possible?URGENT |
Post# 767568 , Reply# 1   7/3/2014 at 00:43 (3,556 days old) by rp2813 (Sannazay)   |   | |
All you can do is take measurements and see if things will line up. The dimensions sound very close, but you may have to do some rigging. Since it's a relatively light weight dryer, if only two out of the four fastening points can be aligned with the stacking hardware, that may be enough, although I'm sure it's not recommended. |
Post# 767606 , Reply# 2   7/3/2014 at 04:27 (3,556 days old) by dj-gabriele ()   |   | |
On top of that you can secure the dryer to the wall with a nylon strap like those used for securing scaffolding or bookshelves to the walls. |
Post# 767642 , Reply# 3   7/3/2014 at 09:39 (3,556 days old) by aamassther (Hendersonville, NC )   |   | |
Check with Frigidaire. But you should be able to do it. Especially since they're both Affinity series. The stack kits look quite generic. They consist of a front bracket and two clips that attach to the back of the washer. You slide the dryer back and then to the left, onto the clips to secure. It's very stable
Post# 769203 , Reply# 4   7/8/2014 at 17:46 (3,550 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 769204 , Reply# 5   7/8/2014 at 17:47 (3,550 days old) by laundromat (Hilo, Hawaii)   |   | |
