Thread Number: 5437
Signs of life... |
Post# 115737 , Reply# 1   3/16/2006 at 21:37 (6,587 days old) by westytoploader ()   |   | |
Under the lid... |
Post# 115738 , Reply# 2   3/16/2006 at 21:37 (6,587 days old) by westytoploader ()   |   | |
Under the lid 2 |
Post# 115739 , Reply# 3   3/16/2006 at 21:38 (6,587 days old) by westytoploader ()   |   | |
Under the lid 3 |
Post# 115742 , Reply# 4   3/16/2006 at 21:48 (6,587 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 115751 , Reply# 5   3/16/2006 at 21:58 (6,587 days old) by westytoploader ()   |   | |
Almost forgot to add... Afterwards, I washed a nice "stress relief" load in the WO-65-2 with Tide and some DIRTY rags from the AMP! |
Post# 115754 , Reply# 6   3/16/2006 at 22:01 (6,587 days old) by unimatic1140 (Minneapolis)   |   | |
Very nice picturs Austin, glad you got the pump running. I would put any water into the inner tub until you can get the machine to spin. If someone removed the T-Key and put it back incorrectly that also could cause the machine not to spin. Did you get your service manual yet? I would study the section on removing and installing the T-Key first, this is sort of a pain to do, and if its not done right, no spin. There are a few other things to check, like is the solenoid bracket attached to the shifter level properly? |
Post# 115755 , Reply# 7   3/16/2006 at 22:02 (6,587 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 115766 , Reply# 9   3/16/2006 at 22:43 (6,587 days old) by brettsomers ()   |   | |
There simply MUST be a video made with the AMP processing a good load of clothes. David |
Post# 115767 , Reply# 10   3/16/2006 at 22:47 (6,587 days old) by golittlesport (California)   |   | |
Thanks for the pictures, Austin. I could never quite get the Maytag AMP water level control...duh! I understood the agitator cap floated up and tripped the switch, but didn't get how different water levels worked. Now I know. Thanks. I came home from a rough day at work yesterday and washed a load in my 55 Unimatic...total stress relief!
Post# 115768 , Reply# 11   3/16/2006 at 22:51 (6,587 days old) by swestoyz (Cedar Falls, IA)   |   | |
Nice progress here! Thanks for the detailed photos of the lid assembly, and the lit control panel! I'm not very versed on the AMP, but found this scan from the Maytag Auto Washer repair manual very useful in trouble shooting your issue. I couldn't find my Maytag Master's manual to see if it was this detailed - I don't remember it being so. Sounds like Robert is on the money with this one. Looking forward to the next step - under the skirt! Ben |
Post# 115948 , Reply# 14   3/17/2006 at 19:48 (6,586 days old) by trainguy (Key West, FL)   |   | |
Post# 116100 , Reply# 15   3/18/2006 at 21:34 (6,585 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
