Thread Number: 54405
New member with new, old, Maytags. |
Post# 767800   7/4/2014 at 00:36 (3,556 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
Hello everybody and Happy 4th.
Not sure if I have to do an intro, but here it goes.. After spending months searching daily for a pair of late '50s to mid '60s Maytag washer and electric dryer, I "settled" for a newer pair I found on Craigslist. The washer is a Model DE808, Serial # 571326 A6. The dryer is a Model A806, Series 01, Serial #752933WW. Here is a before picture. The guy I purchased them from claimed they worked great up until the time he sold them to me which was last weekend. I plan on cleaning & re-painting certain sections of them and making sure all lights work. My questions are, is there any "preventative maintenance" I can do to them before I plug them in and put them to use? Also if someone could help me tell me what model year/s they are I would appreciate that. |
Post# 767824 , Reply# 1   7/4/2014 at 01:52 (3,556 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 767835 , Reply# 2   7/4/2014 at 05:14 (3,555 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 767852 , Reply# 3   7/4/2014 at 08:15 (3,555 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 767854 , Reply# 4   7/4/2014 at 08:25 (3,555 days old) by PhilR (Quebec Canada)   |   | |
Post# 767875 , Reply# 5   7/4/2014 at 10:07 (3,555 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 767915 , Reply# 6   7/4/2014 at 13:01 (3,555 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
Post# 767917 , Reply# 7   7/4/2014 at 13:05 (3,555 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
Post# 767919 , Reply# 8   7/4/2014 at 13:08 (3,555 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
Post# 767922 , Reply# 9   7/4/2014 at 13:20 (3,555 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
Post# 767923 , Reply# 10   7/4/2014 at 13:21 (3,555 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
Thanks to all replies!
@Kenmore71: How were you able to figure out the month and dates on these? @goatfarmer: Is there a thread on how to lubricate the motor slide? Here are some more before pics,excuse the double post, I can't edit or delete it yet. I'm going to finish cleaning, sanding and painting them this weekend.. |
Post# 767969 , Reply# 11   7/4/2014 at 15:41 (3,555 days old) by hippiedoll ( arizona )   |   | |
Post# 768022 , Reply# 12   7/4/2014 at 18:25 (3,555 days old) by beekeyknee (Columbia, MO)   |   | |
Those are nice machines. If you decide you want to get serious, you can become a contributing member and have access to all the site's facilities such as the Searchalator which will help you with research to do all the maintenance that your machines will need. It will be quite a challenge, but it can be done and is rewarding in the end.
Post# 768261 , Reply# 13   7/5/2014 at 21:22 (3,554 days old) by tennblondie78 (Bowling Green, KY)   |   | |
Welcome!!! Congratulations on scoring a great set! I just restored a set exactly like yours. On the washer, you will want to check the injector portion of the fill tube. It will be to the left side of the tub cover under the top. I suggest removing the entire injector portion and replacing it with PVC or something along those lines. Those injectors are a leak problem. It will be whitish plastic with holes in it. While you are in the machine, check all of the other hoses to make sure they are still soft and aren't hard and cracked.
Also check the damper pads. RedCarpetDrew just did a how-to thread on how to do that. That is very important and can cause big headaches down the road. The console lights take an FS-2 starter, available for a couple bucks at Lowes. On the dryer, you will need to check the belt as well a do a good delinting. Check the glides at the front of the drum, they will most likely need replacing. That's not hard to do if you have a rivet gun. I could go on and on, but there's plenty of info on the site. The Super Searchalator will help you a lot, and we will help you with any questions you might have. You'll find there's a ton of knowledge on here, and wonderful people to go with it! |
Post# 769647 , Reply# 14   7/10/2014 at 03:47 (3,549 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
Been meaning to post and respond sooner, got my plate pretty full with projects.
@hippiedoll: Thanks doll, they're just about there. I actually wanted to paint them gloss black, however, I for one have too many projects and two I didn't want to make them "less desirable" or "devaluate" them in case I ever decided to part with them. @beekeyknee: Not sure what you mean by "if you decide you want to get serious"? I spent everyday, for months, looking for a somewhat matching pair, drove over 200 miles to get these and put hours of work into them already... How much more serious can I get? @tennblondie78: Thank you very much for your welcome, and very informative post! Ok,here are some more progress pics, for the most part they are done. These are going to be my "daily drivers". They look right at home in their new laundry room. I went ahead and did a lot of cleaning, sanded and painted whatever panels I felt needed re-painting with appliance epoxy. I replaced all light bulbs including the one for the panels and the one for the drum. (I don't think my washer came with a tub light?) I also replaced the knob on the dryer door with one a mid century one, I personally feel the knob that came on my dryer door looked cheap and out of place. So far they seem to be working ok, I had to adjust the legs on the washer with a level since it was vibrating pretty bad on the spin cycle,it took a few tries but I got it right, no more floor shaking. I know this sounds strange,but,I have this issue (as pictured) with the control panel light for the washer being inconsistent as far staying illuminated. If I twist the light into place and turn the knob to a "on" position, the light will fully illuminate, however once I turn the knob to a off position and then try to turn it back on to a "on" position, it won't light up!? Strangely,(I know this sounds confusing) if I twist the light in but not as far, it will illuminate on the ends only (as pictured as well) but, despite that, it will work when it is and is not supposed to? |
Post# 769648 , Reply# 15   7/10/2014 at 03:54 (3,549 days old) by bootsNslicks14 (The State of Jefferson)   |   | |
Post# 769651 , Reply# 16   7/10/2014 at 04:18 (3,549 days old) by beekeyknee (Columbia, MO)   |   | |
Aaron,
I'm sorry about the "get serious" comment, as I can see you are. I was just trying to convey that the site is more user friendly when you are a contributing member, as you can use the Super Searchalator to narrow your search parameters directly without having to search through Google. It's just easier and quicker. You can search by topic and member screen name to get you to where you want to be. Whichever works for you is fine. From what I've seen, your machines look nice and it looks like things are going well. Brian |
Post# 769695 , Reply# 17   7/10/2014 at 09:07 (3,549 days old) by bluejay (Havre de Grace, MD)   |   | |
Post# 769703 , Reply# 18   7/10/2014 at 09:38 (3,549 days old) by swestoyz (Cedar Falls, IA)   |   | |
Did you replace the bulb in the washer? Usually this is a sign that the bulb is getting weak. You can pick up a replacement (make sure you look for a cool white version to color match the dryer) at your local hardware store/big box store for about 5 bucks. The A806 I brought home from St. Paul a month ago was exhibiting the same behaviors. I replaced the bulb and FS2 ballast starter and everything works great.
You are correct that this series of A806 (I'm assuming this is a Series 2 machine) does not have a wash tub light. Boo Maytag!
Ben |
Post# 769771 , Reply# 19   7/10/2014 at 14:45 (3,549 days old) by hippiedoll ( arizona )   |   | |
they are looking AMAZING!!! you did an outta sight job on cleaning up that lint filter. and the lights all look great. as for the one small issue you are having with the control panel light on the washer, i'm afraid i can't offer any advice as i don't know a thing about mechanics or electrical.
hm hm hm..... but it looks like you've done a GREAT job on your maytags!!! LOVED the pictures. thank you for sharing them. and yes, your maytags do look "right at home in their new laundry room". so happy for you.... :o) |
Post# 769828 , Reply# 20   7/10/2014 at 21:24 (3,549 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 769858 , Reply# 21   7/10/2014 at 23:37 (3,549 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
The enthusiasm on this forum has put a huge grin on my face. I really appreciate all the responses!
@Brian: Thanks,I see where you're coming from, no hard feelings. @bluejay: Thanks, I thought it may be the ballast as well, when I removed it, it made no difference as far as how the light worked.Would that be a sign of the ballast not functioning? For how cheap one is, I don't mind buying a new one and seeing what happens.. @Ben: Yes I replaced all bulbs. I put in the cool white bulbs that you mentioned, it was doing the same thing with the old bulb as well, so I doubt that's the issue. As mentioned I will look into replacing the ballast.Thanks for the part number reference. How can I find out which series of machine I have? @hippiedoll: Thanks for your kind words and I'm glad you are enjoying the pics! @Phil: Thank you and again, glad the photos are being appreciated! |
Post# 770068 , Reply# 22   7/11/2014 at 19:13 (3,548 days old) by norgeway (mocksville n c )   |   | |
Doth that be a NORGE fridge I spy!! |
Post# 770116 , Reply# 23   7/11/2014 at 22:34 (3,548 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
Ben/swestoyz is probably on to something with his comment about the bulb and starter. The last few times I was over at my folks place I noticed that the fluorescent light in the washer was having a hard time getting started. It would struggle and flicker for about fifteen seconds or so, then light. Today when I was there the darn thing wouldn't do anything, so I went to the hardware store and bought a new bulb for it thinking that would solve the problem. Silly me, it made no difference. Feeling pretty foolish at this point I went out to the garage where another A806 sits waiting for attention, took the little starter from it and plugged it in to my folks machine. That did the trick. It turns out that the original bulb, though a little tired, is still in working order. |
Post# 773829 , Reply# 24   7/29/2014 at 16:57 (3,530 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
Been meaning to post sooner, thanks again to everyone for their help. The problem with the control panel light was the FS-2 starter. I purchased a couple from my local Home Depot for a whopping $2.38 and have been enjoying using my Maytags... I actually look forward to doing laundry now,lol.
@norgeway No, that's actually my old Philco, it was my only fridge for over 5 years. When I moved I put it in storage for about 7 months, after moving, I was very bummed to find out it wouldn't get cold anymore. I still hear the compressor kick on, it just won't get cold... I'm guessing the R12 leaked out? I hope not... If anyone knows a thing or two about these old Philcos, please feel free to chime in.. Here are some more pics..
Post# 773831 , Reply# 25   7/29/2014 at 16:59 (3,530 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
Post# 773832 , Reply# 26   7/29/2014 at 17:00 (3,530 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
Post# 773839 , Reply# 27   7/29/2014 at 17:32 (3,530 days old) by pulltostart (Mobile, AL)   |   | |
Post# 773851 , Reply# 28   7/29/2014 at 18:36 (3,530 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 775031 , Reply# 29   8/2/2014 at 20:02 (3,526 days old) by BootsNslicks14 (The State of Jefferson)   |   | |
Thanks Lawrence. It was definitely one of the selling points to my old Craftsman house, bought it from the original family. Was told it was it was installed in 1960, and yes it's got asbestos! I'm hoping I could get a few more years out of the floor before I have to remodel it.. Here's another pic of the floor. @classicaprice: Not sure how I could look in the archives? Is that for upgraded membes only?
