Thread Number: 54470
Using POR-15 |
Post# 768558 , Reply# 2   7/6/2014 at 20:15 (3,575 days old) by xraytech (Rural southwest Pennsylvania )   |   | |
Post# 768567 , Reply# 3   7/6/2014 at 20:44 (3,575 days old) by beekeyknee (Columbia, MO)   |   | |
Post# 768574 , Reply# 5   7/6/2014 at 20:59 (3,575 days old) by bigalsf (Salt Lake City)   |   | |
Thank you both for your tips. I appreciate it! |
Post# 768681 , Reply# 6   7/7/2014 at 07:26 (3,574 days old) by turquoisedude (.)   |   | |
I've successfully used POR15 for washer outer tubs (the 66 Inglis got a good coat...) and just a sanding was all that was necessary. I also did a wash tub, but used their etching compound (I think it's called Metal Clear, but I am not sure) and the end result was great.
To preserve any leftover paint, a sheet of plastic wrap between the can and the lid will definitely work. The manufacturer suggests refrigerating any remaining paint and that seems to help also. The stuff's expensive so I do what I can to make sure I can use all of it! |
