Thread Number: 54553
Maytag Dryer Door Seal Reference Cart |
Post# 769495   7/9/2014 at 18:09 (3,577 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
I found this among some old manuals I picked up recently, and since I've never seen anything like it before I thought it was worth sharing. As you can see it shows all of the seals used on the older Maytag dryers, but the nice thing is that it also shows their profiles, which may be useful when trying to figure out which seal to use as a substitute when the one you need is no longer available. Anyways, it seemed like something that should probably be in the archives for people to find, and now it is.
Post# 769521 , Reply# 1   7/9/2014 at 19:30 (3,577 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 769524 , Reply# 2   7/9/2014 at 19:44 (3,577 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 769590 , Reply# 3   7/9/2014 at 22:24 (3,576 days old) by bluejay (Havre de Grace, MD)   |   | |
Post# 769623 , Reply# 4   7/10/2014 at 00:38 (3,576 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
You're welcome, guys. I'm glad you think it's worthwhile. Along the same lines I found this just this afternoon. It explains a bit of the evolution of one seal in particular, the one that's used on the DG700, DG701, and DG750, to name a few. Strangely, according to this older data these dryers would have all originally used a short lip seal, but by 1980 when the above chart was produced a long lip seal was being called out for them. |
Post# 769744 , Reply# 5   7/10/2014 at 13:09 (3,576 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 769836 , Reply# 6   7/10/2014 at 22:09 (3,575 days old) by dnastrau (Lords Valley, PA)   |   | |
I wonder if anyone knows who made these seals for Maytag? I doubt that they were made in-house. If they are still in business, perhaps they have the dies and could make a few... Andrew S. |
Post# 769947 , Reply# 7   7/11/2014 at 08:52 (3,575 days old) by swestoyz (Cedar Falls, IA)   |   | |
Maytag prided themselves on being able to produce everything in-house, including all the metal, steel, and rubber parts (with the exception of the obvious timers, water valves, motors, etc.). However, I wouldn't be surprised if a somewhat local supplier eventually made the door seals. They were using several local plastic injection manufacturers around Newton to make plastic parts up until 2006.
Ben |
