Thread Number: 54610
US General Electric Range In UK |
Post# 769970   7/11/2014 at 11:30 (3,570 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 769992 , Reply# 1   7/11/2014 at 13:48 (3,570 days old) by peterlondon (london uk)   |   | |
Hey Al Saw this a couple of days ago,all electric cookers are 220 so this will function ok here. I am just at a loss though how the outlets give 110 and the stove input is 220. I wonder if the seller has any other kitchen goodies pete |
Post# 770059 , Reply# 7   7/11/2014 at 18:40 (3,570 days old) by thor (Buenos Aires)   |   | |
...I meant convection blower! |
Post# 770064 , Reply# 8   7/11/2014 at 19:02 (3,570 days old) by peterlondon (london uk)   |   | |
Vali thor, muchas gracias para todo |
Post# 770314 , Reply# 9   7/12/2014 at 19:03 (3,569 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
50 and 60hz..... Makes no difference to me...
I have many 120 volt- 60hz appliances, used with 1500 and 2000 watts light weight/portable travel converters and I also have a big 3000 watt heavy multisocket step down one I almost never bother to use, they all work with european 50hz..... I cannot really tell a difference in matter of speed.....they work just the same as with 60hz.. As pointed out in the US differently than here, they have two 120 volt hot wires going to the house from the pole, and so along with the neutral as we have here of course.... The two 120 togheter, gives 240 volt. Neutral may eventually go to ground at the pole.....just like here... A US stove will work over here, the same way an eu 240 appliances will work in the USA from a 240 volt source.... In a stove, light, clocks, fans etc are serviced just by one of the two 120 volt hots pins of the 240 volt american plugs ( two 120 volt hot pins, neutral pin and ground pin) elements are serviced by both togheter and so of course the neutral (same for everything), making 240 volt.... Depending on the stove, you have to spot which is the wire and more than else if it's just one that " feeds" energy to the lights, clock, service plugs etc and so you have to put a transformer to feed these ones... Also depending on the stove wiring you will have to do that separately or you could actually do it just by wiring one wire to the 120 transformer, and the other to regular 240 volt plug.... But it really depends on how the stove is wired inside and how thick the other wire is.... As long as you are practical with these jobs it's an easy thing to solve.... This post was last edited 07/12/2014 at 19:30 |
