Thread Number: 54672
Neptune washer vibrating violently on the spin cycle |
Post# 770586 , Reply# 1   7/13/2014 at 16:18 (3,573 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Not an expert on Neptunes, but if something like this happens most likely something got loose. Is it just the comforter that causes this behavior or every load since then? |
Post# 770587 , Reply# 2   7/13/2014 at 16:20 (3,573 days old) by norgechef (Saint George New Brunswick )   |   | |
Seems to get louder...I'll have to take the back panel off in a few days and have a look. |
Post# 770599 , Reply# 4   7/13/2014 at 17:47 (3,573 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Once you know the machine is level. I would look to see if one of the shocks is leaking or froze up. I have seen this in a friend's Laundromat where a machine had a suspension failure @1000 RPM and it knocked the front panel loose and bent the side cabinet. A good indicator of this would be if the drum is tilted or not level in the door boot as was the case in this SQ.
WK78 |
Post# 770648 , Reply# 5   7/13/2014 at 20:18 (3,573 days old) by Yogitunes (New Jersey)   |   | |
check the suspension parts as well as the balance ring.....
just to be correct...according to my brochures and literature from inside the machine....these spin at 1000 rpm....not 800.... max extract option just increases the time, and also increases to the higher speed if using permpress, or gentle/handwash cycles... |
Post# 770770 , Reply# 7   7/14/2014 at 09:02 (3,573 days old) by yogitunes (New Jersey)   |   | |
you might want to try a load with the front off, keep the door on and closed as normal, you don't need the screws in place, it will run fine for a test like this....and also keep the top up, and maybe the back panel off...and try to observe if anything is out of place or loose, like wiring....you will be surprised at how much bouncing goes on inside....but your looking for something excessive....
depends too on what you may be washing at that moment.....things like sheets can ball up, or items get trapped into the pockets and throw the balance off....sometimes the machine will back off to compensate... keep us posted....we'll get you back on track.... those struts pull out of those suspension post.....its possible, the springs inside could be worn or broken......just keep an eye for loose play or favoring to one side rather than staying even.... |
Post# 770786 , Reply# 8   7/14/2014 at 10:50 (3,573 days old) by Frigilux (The Minnesota Prairie)   |   | |
