Thread Number: 54783
I found these |
Post# 771714 , Reply# 1   7/18/2014 at 16:47 (3,541 days old) by PhilR (Quebec Canada)   |   | |
Great! I have a washer that matches your dryer! I also have the same dryer in white but I'll need to fix a few things on it and repaint it avocado! I have no pics of the dryer, the white one pictured beside it is another one that works and it just found it's matching washer!
I included two scans of my owner's manual and a nice illustration that Ken made (which I did modify just a bit!). This post was last edited 07/18/2014 at 17:03 |
Post# 771728 , Reply# 2   7/18/2014 at 17:21 (3,541 days old) by hippiedoll ( arizona )   |   | |
Post# 771743 , Reply# 3   7/18/2014 at 19:51 (3,541 days old) by dynaflow (rockingham nc)   |   | |
Post# 771759 , Reply# 5   7/18/2014 at 21:48 (3,541 days old) by jamman_98 (Columbia, SC)   |   | |
Post# 771763 , Reply# 6   7/18/2014 at 21:55 (3,541 days old) by brainardcooper (Columbia, SC)   |   | |
You need to come over to see them when I get them set up! |
Post# 771799 , Reply# 7   7/19/2014 at 00:28 (3,541 days old) by atari_master ()   |   | |
you interested in selling them |
Post# 771940 , Reply# 9   7/19/2014 at 18:26 (3,540 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 771945 , Reply# 10   7/19/2014 at 18:55 (3,540 days old) by PhilR (Quebec Canada)   |   | |
Post# 771969 , Reply# 11   7/19/2014 at 21:21 (3,540 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 771970 , Reply# 12   7/19/2014 at 21:26 (3,540 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 772788 , Reply# 14   7/24/2014 at 00:03 (3,536 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
So common on these machines. Will need new bearings which is a tough job but not impossible. I did replace them in my '76 1-18 a while back and the spin is very quiet now. Problem is I ate up the threads on the shaft and can't get the nut back on far enough to have an operational tub break. The leak could likely be the tub seal which sits, guess where...right above the roaring, rusty bearings. The seals are still out there but harder to find and they have to be chip and crack free or they will leak even if never used before. I learned that the hard way when I bought a new one that had a hairline crack in it.
Hope this gives you a little help. I also have a scanned copy of a 1-18 repair manual that can help if you think you'll be repairing your machine. Jon |
Post# 772952 , Reply# 15   7/24/2014 at 23:43 (3,535 days old) by brainardcooper (Columbia, SC)   |   | |
I am guessing the repair manual is on the "Manuals" area of the site.
Also, where does one look for that bearing & the seal? I saw a couple of bellows on Craigs List. Was going to check the parts list to see if they were for the 1-18.
Post# 772970 , Reply# 16   7/25/2014 at 01:07 (3,535 days old) by PhilR (Quebec Canada)   |   | |
