Thread Number: 54959
Bosch Drain hose |
Post# 773416 , Reply# 2   7/27/2014 at 12:39 (3,532 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
The bekos as aeg03 said do a timed fill which on the basic ones is a low level rinse and no top up makes for a bad rinse, the higher end models static fill up the door and then tumble soaking up the load.
Bosch washing machines used to be poor rinsing from 98-2005 because there standard cycles used as little as 39 litres. Thankfully they are around 45litres now. The synthetic cycles take in more. If you have rinse plus or aqua plus then you may need to use that. My new massive Bosch rinses well due to the paddle design. Darren
Post# 773424 , Reply# 4   7/27/2014 at 13:15 (3,532 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
Post# 773560 , Reply# 6   7/28/2014 at 07:44 (3,531 days old) by liberatordeluxe (UK)   |   | |
The drain pump doesn't sound right to me. How do I upload a video? |
Post# 773566 , Reply# 7   7/28/2014 at 09:26 (3,531 days old) by AquaCycle (West Yorkshire, UK)   |   | |
We had a Beko Excellence 1400 for a while - that was one of the best rinsing modern washers I've ever used. We now have the Miele plumbed in and, as it has since day 1, always rinses clear. I usually put heavy items like towels and jeans through the spinner to get them as dry as possible before going in the dryer, and the water extracted from that is always clear.
Post# 773570 , Reply# 8   7/28/2014 at 10:08 (3,531 days old) by AquaCycle (West Yorkshire, UK)   |   | |
Post# 773601 , Reply# 9   7/28/2014 at 14:01 (3,531 days old) by liberatordeluxe (UK)   |   | |
Video of Bosch pump CLICK HERE TO GO TO liberatordeluxe's LINK |
Post# 773602 , Reply# 10   7/28/2014 at 14:03 (3,531 days old) by liberatordeluxe (UK)   |   | |
Bosch video CLICK HERE TO GO TO liberatordeluxe's LINK |
Post# 773603 , Reply# 11   7/28/2014 at 14:04 (3,531 days old) by liberatordeluxe (UK)   |   | |
Www.youtube.co.uk/boschpump |
Post# 773610 , Reply# 12   7/28/2014 at 15:04 (3,531 days old) by liberatordeluxe (UK)   |   | |
v6ab92mriq91@m.youtube.com |
Post# 773611 , Reply# 13   7/28/2014 at 15:05 (3,531 days old) by liberatordeluxe (UK)   |   | |
bOSCH Pumop CLICK HERE TO GO TO liberatordeluxe's LINK |
Post# 773630 , Reply# 14   7/28/2014 at 17:45 (3,531 days old) by HotpointWMA64 (North Yorkshire)   |   | |
have you got a bosch logixx 10??? ive wanted to see atleast a video of one of those for years. never got my hands on one:( |
Post# 773714 , Reply# 17   7/29/2014 at 05:25 (3,530 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
Your links dont work liberator deluxe. |
Post# 773845 , Reply# 18   7/29/2014 at 17:57 (3,530 days old) by dascot (Scotland)   |   | |
Interesting - I remember instructions being very clear that the drain had to come up to a certain height above floor to avoid syphoning back. Can't think why it would have needed that if the pipes had been at the top. |
Post# 776419 , Reply# 19   8/9/2014 at 08:45 (3,519 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 776422 , Reply# 20   8/9/2014 at 09:06 (3,519 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
If you want to share a video here, click on "Share" under the video. You will see another "Share" a bit lower. It contains a link. Click on that link so it will highlight.
If it is highlighted, you can do two things: 1. Click right with your mouse while you have your mouse on the highlighted link. It will say "Copy", click on that. OR: 2. Press the buttons "ctrl" and "c" at the same time. The copied link is now in your memory. Then go to the message here where you want to post your Youtube video in ("Post text"). Again two options: 1. Click right with your mouse again, one of the options is "Paste". Click on that. The link will show up. OR: 2. Click with your mouse in the spot where you want to post the link. Press the buttons "ctrl" and "v" at the same time. The will will show up. You can finish your text and post your message. The video will be shown in your message if you have posted the link in the "Post text" window. If you post it in "URL Link to share" it will only show the link to the video on Youtube. I hope this helps. |
