Thread Number: 55370
Anybody have a Maytag door seal for a de702? |
Post# 777663   8/16/2014 at 22:21 (3,532 days old) by classiccaprice (Hampton, Virginia)   |   | |
Volvoguy87 and I were chatting and I figured I'd ask., I have a de702 and he has a de700 and both need door boots. As luck would have it, I found one today! However, that doesn't help Dave. Being the amazing friend I am, I thought I'd ask you all. Does anyone have an extra door seal 302448, 3-2448, 3-11436, or 3-2400 that they would consider selling?
Thanks! |
Post# 777746 , Reply# 1   8/17/2014 at 12:08 (3,532 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
This is one of those parts that gets a lot of requests but is in very short supply. I have a spare NOS seal that's going on my DG701 at some point, so I can't spare it.(no pun intended) Considering how critical it is to the proper operation of these old HOH machines this is one part that really needs to be reproduced. I know some folks think this would be prohibitively expensive, but considering that the part was extruded, and extrusion dies are the least expensive to make, it's well worth looking into. It could end up being more affordable than some are thinking. |
Post# 777894 , Reply# 2   8/18/2014 at 00:58 (3,531 days old) by bluejay (Havre de Grace, MD)   |   | |
I'm in the same boat; I just have the one spare. It's part #312231 and says it's a replacement for 3-2448. The instruction sheet states this specific seal will fit 641C, 741C, 642C, 742C, 700, 701, 702, 750, and D20 models. It also appears to replace 3-12238 which fits the 606, 806, and 906.
The instructions also indicate that if it's being used for a dryer without a window door to trim off a 1/2 inch. |
Post# 777940 , Reply# 3   8/18/2014 at 10:43 (3,531 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
Post# 778042 , Reply# 4   8/18/2014 at 18:52 (3,531 days old) by bluejay (Havre de Grace, MD)   |   | |
David, My apologies on the poor quality; the bag is still sealed and it kept picking up the flash. I included a shot of the instruction page; it apparently fits a LOT of models. |
Post# 778077 , Reply# 6   8/18/2014 at 21:18 (3,530 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
I think Andrew is likely correct about the instruction sheet that came with the gasket you picked up, but I'm still interested in more information on it. I did the little drawing below of the 302448 gasket profile some time back. It was a well used gasket, so the measurements are probably close but not exact, especially the 1 11/32" width. It spent many years with a door closed against it which flattened out the outer lip. With this in mind, how does the width of your gasket compare?
