Thread Number: 55597
General Electric V12 Washer Water Pump Assembly Line |
Post# 779865   8/28/2014 at 07:38 (3,526 days old) by Unimatic1140 (Minneapolis)   |   | |
For those who find manufacturing interesting today's Product Stat post on the GE washer pump assembly is quite cool...
CLICK HERE TO GO TO Unimatic1140's LINK |
Post# 779941 , Reply# 1   8/28/2014 at 16:56 (3,526 days old) by bajaespuma (Connecticut)   |   | |
Wonderful! Enhanced when you listen to the following while reading the article: CLICK HERE TO GO TO bajaespuma's LINK |
Post# 779947 , Reply# 2   8/28/2014 at 17:17 (3,526 days old) by washman (o)   |   | |
Notice the screws holding it together? That would suggest it could be taken apart and fixed. No need to toss the whole thing when it breaks. And no plastic either! |
Post# 779982 , Reply# 3   8/28/2014 at 19:43 (3,526 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Very Cool, Thanks or posting Robert.
Yes these pumps can be taken apart to fix them, Just LIKE the plastic pumps that replaced them by the mid 1960s. These metal pumps had very poor durability because of corrosion issues that lead to pin-hole leaks [ if something was built this badly today there would probably be a class action suit because of all the water damage these pumps caused, LOL ] , they also often clogged with clothing threads and lint because the inside surfaces would get so rough from the corroded Pot-Metal material they were made from. John L. |
Post# 780034 , Reply# 4   8/29/2014 at 00:28 (3,525 days old) by tolivac (greenville nc)   |   | |
Maybe if the pumps were made from stainless steel then it wouldn't have corrosion issues-then you could take it apart to fix it.Add a SS impeller,too.But for washers,the poly pumps do hold up better. |
Post# 780216 , Reply# 6   8/30/2014 at 02:16 (3,524 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
