Thread Number: 55603
A700 metal pump failure |
Post# 779949   8/28/2014 at 17:24 (3,521 days old) by bluejay (Havre de Grace, MD)   |   | |
I have a Maytag from '61 that came with the original drain pump. The washer and matching dryer had been sitting for some time, but I was able to get both back up and running.
The original metal pump finally developed a leak (it was dripping like a faucet out of the bottom onto the pulley), so I have replaced it with a poly pump. My question is (and I hope it isn't stupid), do I need to punch the hole for the bleach dispenser? It has the protrusion for the bleach dispenser hole, but it appears to be sealed off. I figure the answer is yes, but wanted some confirmation in case that isn't the solution.
CLICK HERE TO GO TO bluejay's LINK |
Post# 779950 , Reply# 1   8/28/2014 at 17:26 (3,521 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 779960 , Reply# 2   8/28/2014 at 18:25 (3,521 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 779963 , Reply# 3   8/28/2014 at 18:32 (3,521 days old) by bluejay (Havre de Grace, MD)   |   | |
Post# 779978 , Reply# 4   8/28/2014 at 19:32 (3,521 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
In MT poly pumps, I am sure that one of the other MT experts will come in with the answer, but when you used to buy a new poly-pump the instructions with the pump specified the correct hole size [ yes Ben you are correct it should not be too big or too small ] I seem to remember 3/16". The hole should diffidently be drilled, I would NOT try punching the hole as you not only could ruin the pump but you would never get the correct size, it needs to be a drilled orifice for the bleach dispenser [ and washer ] to perform correctly.
Jason, this MT pump design was about the most durable pump ever used in an automatic washer, BUT the metal MT pumps were too thin and had many problems with pin hole leaks and the only reason yours is around 50 years after being built is that the machine saw little or no use for a substantial part of its life. Turn your old pump into a display but there is no point trying to fix it as it will only leak again. The plastic PP is yet another example of how newer machines are built to last longer, a plastic PP will easily outlast 5 of the old pot-metal pumps in normal use. John L. |
Post# 780021 , Reply# 5   8/28/2014 at 22:56 (3,521 days old) by bluejay (Havre de Grace, MD)   |   | |
John, I see your point about the metal pump. The exterior looked fine, but when I opened it up...whoa. It wasn't too bad, considering it is a 50 year old pump, but it won't be going back into service anytime soon. Interestingly, the top and bottom were sealed with a cork gasket.
I kind of jumped the gun and punched out the hole; I did a load of laundry and everything worked accordingly. I don't use bleach any more (I switched to bluing liquid) for my whites, so I'm not terribly worried, but I'm monitoring the next few washes to be sure nothing surprising occurs.
Post# 780482 , Reply# 6   8/31/2014 at 20:22 (3,518 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 780582 , Reply# 7   9/1/2014 at 08:03 (3,518 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
