Thread Number: 55783
Maytag Dryer Help |
Post# 781812 , Reply# 1   9/6/2014 at 05:45 (3,491 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
Unplug the dryer, take the front panel off. Then you take off 4 screws, and the front tub support comes off. Check condition of the support pads on the support while you have it off. Put the belt around the tub, with the grooved side up. Replace the front tub support. Go to the back of the dryer, and there is a small access panel in front of the motor. Remove it, and thread the belt through the motor pulley, and idler pulley. Replace the rear access panel, the front panel, plug it back in, and enjoy. |
Post# 781824 , Reply# 2   9/6/2014 at 07:24 (3,491 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
