Thread Number: 55819
KDS-18 vs. KDS-19 |
Post# 782101 , Reply# 1   9/7/2014 at 10:05 (3,516 days old) by carmine (Detroit)   |   | |
For some reason the new photo loader isn't showing up on my phone (although I has in the past... Computers!) So here is the 19... |
Post# 782103 , Reply# 2   9/7/2014 at 10:15 (3,516 days old) by carmine (Detroit)   |   | |
Also, there appears to be evidence of a prior repair. Any idea whay this is? Common failure point? |
Post# 782130 , Reply# 3   9/7/2014 at 12:23 (3,516 days old) by appnut (TX)   |   | |
The 19 heats its own water and only offers a no heat dry. The 18, you have to keep water heater set at 140 degrees minimum. No heat dry is an option when button pushed in. It should pop out when the door latch is lifted. The 18 was the last to offer the 3rd wash level (on the top of the tank) Constant Rinse. The 18's Soak & Scrub is much longer cycle than the 19's version and probably does a better job in my opinion. |
