Thread Number: 55864
HELP! MAYTAG DISHWASHER TIMER RE-ASSEMBLY!!!! |
Post# 782467 , Reply# 1   9/8/2014 at 22:01 (3,516 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
In reply seven you can see how one end of the wire spring tucks into the hole, while reply twenty six shows where the other end goes. If it isn't clear enough or you need more photos, let me know and I'll see what I can come up with. CLICK HERE TO GO TO d-jones's LINK |
Post# 782485 , Reply# 4   9/8/2014 at 23:45 (3,516 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
These are really very simple mechanisms, and once you figure them out you'll never forget. The first photo shows the device that prevents reverse travel of the cam wheel(the disc with all the teeth around the edge). It's installed with the little peg sticking up as shown. The next photo shows the little drive lever installed with that same peg engaged at one end of the slot running lengthwise in the tail end, and the motors little drive peg engaged in the other slot that runs crosswise in the wider portion. You can also see the wire spring hooked under the tab at the very end of the drive lever. These are excellent little timers, and very easy to work on once you get the hang of them. Let me know if need more help. |
Post# 782676 , Reply# 6   9/9/2014 at 20:17 (3,515 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
