Thread Number: 55967
Geared washarm support removal GE GSD2800 |
Post# 783391   9/13/2014 at 01:09 (3,506 days old) by funktionalart (Rison, AR)   |   | |
I want to remove this from the tub so I can clean. When I received the machine this component didn't turn at all (although washarm itself does turn on its orbital axis). When I pulled the motor/pump off, I managed to loosen this part from the underside...and now I can turn fairly freely in either direction it when I grasp it by the geared edge.
Here's what I need to know: 1) Is it supposed to turn when the machine is running or be tightly affixed to tub bottom? Has is just been locked tight to the tub by mineral deposits? 2) How do I fully remove it without damaging it? Thanks in advance for any help available!
