I've just seen a Haier Top-Load Washer in a nearby 2nd Hand Appliance Store. I'm guessing it is approx somewhere around Mid-1980's or maybe even early 1990's. I'm going back either on Monday or Tuesday, to get the Model and Serial Number off of it. It has a Wobbily Suspension, similar to the newer GE/Hotpoint Washers, along with a Stainless Steel Tub, but it has an Ugly Medium Gray WP Agitator. Does anyone know which Manufacture that this Washer is actually Modeled after? It has a fairly basic Setting configuration of a couple/few Cycles {Normal, Perm Press and Delicate or Soak Cycles} Water Temp and Variable Water Levels. I will write down for sure, the Cycles, Temp and Level Selections when I go back to check it out again.
If it is Modeled after both WP/GE would it be easy or difficult to locate Parts as needed if any later on, for Repairs? I would gratefully appreciate any and all help both now and later on.
Peace and Happy interesting Laundry Washing Machines, Steve SactoTeddyBear...
