Thread Number: 56237
POD 9-26-14 Whirlpool Imperial Washer for 1956 |
Post# 785770 , Reply# 1   9/26/2014 at 07:04 (3,498 days old) by cycla-fabric (New Jersey (Northern))   |   | |
I don't think it had a cold water option at this time. One other thing I noticed when this ad comes up is the water level selection switch and the amount of water in the tub, they don't match if you look closely. I upper picture shows a low water level selection yet the tub looks full. And the bottom picture shows med level, yet again it looks full again.
Doug |
Post# 785772 , Reply# 2   9/26/2014 at 07:50 (3,497 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 785774 , Reply# 3   9/26/2014 at 08:00 (3,497 days old) by turquoisedude (.)   |   | |
you replace the original water valve with a 'modern' replacement! When John and Jeff rebuilt mine that's what happened - the default rinse temperature for all cycles (including the spray-rinses) was warm originally. I don't remember what the original valve looked like, but I suspect it was a thermostatic one. |
Post# 785782 , Reply# 4   9/26/2014 at 10:06 (3,497 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Thank you, DUDE! |
Post# 785824 , Reply# 5   9/26/2014 at 16:30 (3,497 days old) by roto204 (Tucson, AZ)   |   | |
Post# 785844 , Reply# 6   9/26/2014 at 19:27 (3,497 days old) by jimmler (Nipomo, CA)   |   | |
Post# 785966 , Reply# 9   9/27/2014 at 20:28 (3,496 days old) by appnut (TX)   |   | |
