Thread Number: 56435
Stuck! OR How do I coax this washer tub out... |
Post# 787395   10/5/2014 at 09:54 (3,488 days old) by turquoisedude (.)   |   | |
OK, I'm embarrassed but I'm literally stuck here....
Having received my 'make room in the garage for a second car or I'll call the scrap guy' orders from Hubby before he left for Brazil I was anxious to part out the guts of an 80s Inglis washer that Phil and I rescued from the curb in Montreal a while back. I knew the machine had some serious rust damage - the lip of the inner tub is shot and I had to burn the flipping agitator off the drive post. I suspect the center post is badly rusted, too. I had lots of fun getting the tub nut off and now, well, I just can't seem to make the dang tub budge.
I have tried everything I can think of (including standing in the tub, which nearly send me arse over teakettle since the machine is no longer in a cabinet... ) but I can't seem to get the darn thing out.
I'd really like to save the wash tub from this one - it looks to be in great condition and it's a smaller capacity one that could come in handy with one of Whirlpool/Kenmore/Inglis machines in my collection.
Please let me know if you have any ideas!
Post# 787421 , Reply# 1   10/5/2014 at 12:20 (3,488 days old) by Yogitunes (New Jersey)   |   | |
well, first I would spray some oil or nut breaker fluid down the center, then, since this is only a body, presuming the tranny is off and the spin shaft if left, put this up on a few bricks, and with a rubber mallet and a large socket and extension, hammer the drive shaft down and out of it....or even have someone pull up on the tub while doing this....
let us know how you make out..... |
Post# 787430 , Reply# 2   10/5/2014 at 12:53 (3,488 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 787432 , Reply# 3   10/5/2014 at 13:00 (3,488 days old) by bigalsf (Salt Lake City)   |   | |
Paul, John took the words out of my mouth! It may seem crazy, but I've done the same thing too many times to count and it works every time (if you do this outside your neighbors will think you've gone nuts!) Good luck & be careful jumping in there! :) |
Post# 787469 , Reply# 4   10/5/2014 at 16:13 (3,487 days old) by turquoisedude (.)   |   | |
Grrrr..... I tried doing as Martin said and putting the baseplate up on blocks. I figured I had nothing to lose by trying to get into the tub again, but still no luck! I was being very careful, though, as the tub is not as stable as it would be in a washer. I tried giving shaft a good dose of WD40 (all I have around the house) and after a good soak, I tried to pound, but still no luck. I think the gods of Inglis are mad at me again... I'll be doing a load of laundry in the 66 Sterling tonight - maybe that will reverse my fortune!
I hate to give up on what looks like a good tub, but geez, this one is good and stuck. |
Post# 787475 , Reply# 5   10/5/2014 at 16:40 (3,487 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 787570 , Reply# 7   10/6/2014 at 00:15 (3,487 days old) by PhilR (Quebec Canada)   |   | |
Post# 787584 , Reply# 8   10/6/2014 at 03:35 (3,487 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
a Frigidaire 1-18 machine with the same problem! I even had it hoisted up from the floor joists, hanging by the tub base wailing on it with a 5 lb hammer. It never budged, I don't miss it, it went to the scrape heap, it got what it deserved,I DONT miss it!
But you can also try the "benign neglect" method get some PB spray , soak, walk away , each day come back spray, soak. In a few days try the Combo method. PB does work that way of course PB didn't exist in my early days of washerdom.
CLICK HERE TO GO TO jetcone's LINK |
Post# 787611 , Reply# 9   10/6/2014 at 07:23 (3,487 days old) by Yogitunes (New Jersey)   |   | |
Post# 787638 , Reply# 10   10/6/2014 at 10:47 (3,487 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
after working on vintage cars for 40+ years, I'e found AeroKroil to be the best by far. Developed for the airplane industry, it can get in spaces as small as 1 millionth of an inch, and works far better than PB or WD... it's gotten stuff loose for me that nothing else but an acetylene torch could touch. Not sold in stores, but you can get it online and well worth the trouble if you work on old mechanical stuff.
I always keep a can of both spray and drip-can kinds on hand. For a preservative/rust preventive, Boe-Shield is the best, also developed for airplanes, in this case for airplane storage by Boeing. Good luck with your loosening project Paul! |
Post# 787952 , Reply# 12   10/8/2014 at 08:02 (3,485 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
never heard of those I will check them out ASAP !!
This is what I use for anti-seize before reassembly:
