Thread Number: 56749
Maytag A712 washer |
Post# 790577 , Reply# 1   10/25/2014 at 13:38 (3,464 days old) by rp2813 (Sannazay)   |   | |
Post# 790580 , Reply# 2   10/25/2014 at 14:41 (3,464 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 790586 , Reply# 3   10/25/2014 at 15:02 (3,464 days old) by BGPatterson83 ()   |   | |
The cabinet vibrates a bit when its on spin but maybe its fine. I centered the drum but when its done washing its always a bit to the right-back. Maybe nothing is wrong? |
Post# 790596 , Reply# 4   10/25/2014 at 15:44 (3,464 days old) by rp2813 (Sannazay)   |   | |
It sounds fairly normal. Just be sure the machine is level front to back and side to side as Kenny advised.
From what you described you may need to make minor leveling adjustments. These Maytags are so heavy there shouldn't be any vibration during spin. Ours never vibrated during spin, but the front cabinet panel would often silently quiver. |
Post# 790604 , Reply# 5   10/25/2014 at 18:20 (3,464 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Maytag's can vibrate especially on non-concrete floors.
First thing is turn all four feet in as far as possible and end up with a level washer, and be sure to tighten all four lock nuts against the bottom of the washer. If the washer still has any vibration issues, take the front panel off and see if there is any black dust around the cast aluminum damper in the center of the washer, if so the damper pads are gone and the washer is not far behind. Replacing damper pads and the cast damper is a big job that is usually not worth the time and money it takes. Good Luck, let us know what you find, John L. |
