Thread Number: 56894
/ Tag: Wringer Washers
GREEN EASY WRINGER! |
Post# 791933   11/4/2014 at 00:45 (3,460 days old) by WaterWitch (Pomona, Calif.)   |   | |
Hi everyone. Lookie what we have here. A GREEN Easy Wringer. I'm guessing this is mid 1930's? The wringer rolls are in great shape, and are actually still soft. No chips in the enamel tub. The pump isn't functioning, but may just need adjusting. Overall, this machine is in great condition. I will need to replace the drain hose, it's dry and cracked. Who out there is an "Easy" collector savvy in this brand?
Post# 791937 , Reply# 1   11/4/2014 at 02:58 (3,460 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 791948 , Reply# 2   11/4/2014 at 04:54 (3,459 days old) by WaterWitch (Pomona, Calif.)   |   | |
Hi Toploader55,
Yes I have been out of circulation for a while. I do plan on uploading a video of this washer just as soon as I tie up a few loose ends on it. I need to replace the drain hose. This might be tricky as the metal gooseneck on this is machine pressed to the hose unlike a maytag that is threaded. I also need to check out why the pump isn't functioning. |
Post# 791975 , Reply# 3   11/4/2014 at 09:03 (3,459 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 792011 , Reply# 4   11/4/2014 at 14:23 (3,459 days old) by bradross (New Westminster, BC., Canada)   |   | |
Post# 792075 , Reply# 6   11/4/2014 at 22:22 (3,459 days old) by WaterWitch (Pomona, Calif.)   |   | |
Yes this machine is really pretty in person. Do you have any pictures of your machine? I noticed that the suction cups on this have what seems to be a kind of "breathing" configuration. As the cups are pushed down, water is forced up threw holes at the top, and then redirected out from a few little slits located at the tops of each cup. Other that really kicking up the suds, I wonder why this design came into play? Here is a picture of it on it's way home.
Post# 792196 , Reply# 7   11/5/2014 at 12:08 (3,458 days old) by whirlaway (Hampton Virginia)   |   | |
The cups rotate around as they go up and down! I need a universal joint between the gearbox and the spinner.I have a 48 model for a donor machine I should look to see if it has one.Your machine is nice,is it heavy? Bobby |
Post# 792245 , Reply# 8   11/5/2014 at 17:07 (3,458 days old) by WaterWitch (Pomona, Calif.)   |   | |
Yes, it is a little on the heavy side. I came across an ad of the spinner you have I think. It's dated to 1932. It's funny, it claims that it's important that baby clothes are soft, otherwise you run the risk of scratching their skin, ultimately causing an infection! Lol! "So if you love babies, then you need to buy an Easy Brand Washer!"...
Post# 792249 , Reply# 9   11/5/2014 at 17:34 (3,458 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 792261 , Reply# 10   11/5/2014 at 19:32 (3,458 days old) by lamont ()   |   | |
I would assume the cups are vented because otherwise, they would act like a diving bell and trap air inside them. |
Post# 792407 , Reply# 11   11/6/2014 at 19:22 (3,457 days old) by WaterWitch (Pomona, Calif.)   |   | |
Post# 792517 , Reply# 13   11/7/2014 at 12:58 (3,456 days old) by roto204 (Tucson, AZ)   |   | |
