Thread Number: 57124
/ Tag: Modern Dishwashers
Bosch dishwasher |
Post# 794310   11/16/2014 at 16:35 (3,419 days old) by Nmassman44 (Brooksville Florida)   |   | |
Here are a few pics of the Bosch dishwasher I installed for friends of ours...
Post# 794312 , Reply# 1   11/16/2014 at 16:39 (3,419 days old) by Nmassman44 (Brooksville Florida)   |   | |
More pics....this dishwasher is 18 inches and has plenty of power to get the job done and it's quiet too.
Post# 794358 , Reply# 2   11/16/2014 at 21:04 (3,419 days old) by joeypete (Concord, NH)   |   | |
Post# 794373 , Reply# 3   11/16/2014 at 21:44 (3,419 days old) by washdaddy (Baltimore)   |   | |
Did I notice two small washarms for the top rack? one front and one in the back? |
Post# 794461 , Reply# 4   11/17/2014 at 10:42 (3,418 days old) by logixx (Germany)   |   | |
Post# 794533 , Reply# 5   11/17/2014 at 19:13 (3,418 days old) by nmassman44 (Brooksville Florida)   |   | |
The friends that have this dishwasher replaced a 2 year old Danby that went up in smoke...literally...smoke was coming from the controls and under at the motor. I told them stay away from those Chinese built dishwashers or you will have the same problem again. I was steering them to a Miele 18 incher but they couldnt justify the $1600 price tag...I can understand that. So the Bosch was on sale at Lowes and it was a special order. I installed it, which I might add, was very easy. I couldnt install the dishwasher all the way into the cabinet since the drain pipe from the sink rides against the wall and takes up some space bhind the dishwasher.
Its very interesting to listen to when its running. It sound like a normal dishwasher in the beginning, then after a few mins it quiets down quite a bit to almost silent. The wash pump speed is variable and the dishwasher also alternates the wash arms as well. Performance is very impressive and the racks are much more thought out and they can fit more into the dishwasher than the Danby. |
Post# 794551 , Reply# 7   11/17/2014 at 20:08 (3,418 days old) by nmassman44 (Brooksville Florida)   |   | |
Well in the manual for this machine, it makes it abundantly clear that one has to use rinse aid or things will not dry properly. It still uses the walls to condense the water in the air after the final rinse. What was odd was the fact that this dishwasher didnt come with insulation pads covering the top and back of the unit. It does have the cabinet panels like any German built dishwasher but on the sides. For an 18 incher, it has quite a bit of space and this one also has that top spinner to shower the top rack. They dont have the issue like the last dishwasher had, with food bits on top of the load. Filling is also done by a pressure/ motor sensor so water levels are always at optimum. The other dishwasher used to underfill and they would have to add water to stop cavatation in the pump or the load would not get clean. They also had issues with detergent tabs not dissolving in the Danby and they switched to powder after I told them that would be he best bet, yet they had issues with dirt on the door.
Build quality is much better with the Bosch machine compared to the Danby. |
