Thread Number: 57473
/ Tag: Vintage Dryers
Maytag Gas Dryer GDG606 Heating Problem |
Post# 798480 , Reply# 1   12/10/2014 at 19:46 (3,418 days old) by jrsrvm ()   |   | |
Sorry, I meant to type the model number as GDG608. |
Post# 798525 , Reply# 2   12/11/2014 at 02:32 (3,418 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 798800 , Reply# 6   12/12/2014 at 20:27 (3,416 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
If you are hearing the click [ the sound is one of the two gas valves opening ] and you are seeing the ignitior heat the problem is in the gas burner area and NOWHERE else.
If the ignitior stays on and does not cycle off in a minute or so you have a bad flame sensor. If the ignitor shuts off in a minute or two you have bad valve coils or a bad gas valve it self. |
Post# 798865 , Reply# 7   12/13/2014 at 11:47 (3,415 days old) by jrsrvm ()   |   | |
The ignitor doesn't come on at all. So, I can't even get to the gas valve opening up yet. |
Post# 798923 , Reply# 8   12/13/2014 at 18:16 (3,415 days old) by lamont ()   |   | |
Will it fire on any heat/cycle setting? If not, see if you have voltage out of the timer. the symptom you described above sounds like a bad timer. |
