Thread Number: 57560
/ Tag: Vintage Dryers
Maytag DE106 Wont heat, very confusing. |
Post# 799613 , Reply# 1   12/17/2014 at 20:45 (3,415 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 799614 , Reply# 2   12/17/2014 at 20:46 (3,415 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 799620 , Reply# 3   12/17/2014 at 21:57 (3,415 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 799621 , Reply# 4   12/17/2014 at 22:17 (3,415 days old) by interceptor1985 ()   |   | |
Both the thermostats and the element tested fine and the timer acts like it it ok. |
Post# 799625 , Reply# 5   12/17/2014 at 22:52 (3,415 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 799627 , Reply# 6   12/17/2014 at 23:27 (3,415 days old) by Kenmore71 (Minneapolis, MN)   |   | |
So, do you have a meter to check the continuity of the heater circuit through each component? Do you know how to do this? That's how you find the bad link and fix this issue.
Post# 799634 , Reply# 7   12/17/2014 at 23:54 (3,415 days old) by interceptor1985 ()   |   | |
^Awesome, Thank you, I'll give it another look tomarrow, as I'll have to pull it back out of its spot and take her apart again, since it makes a bit of noise I can't do it after 10:00PM... |
Post# 799700 , Reply# 8   12/18/2014 at 17:29 (3,414 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 799706 , Reply# 9   12/18/2014 at 18:15 (3,414 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Goat beat me to it. I would pull outlet as well and look for damage. |
Post# 799712 , Reply# 10   12/18/2014 at 19:17 (3,414 days old) by interceptor1985 ()   |   | |
I can check it out but if anything electrical needs replaced I'll have to talk to the landlord about it since i'm renting the house. |
