Thread Number: 57575
Washers and water turnoff |
Post# 799777 , Reply# 1   12/19/2014 at 10:46 (3,409 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 799779 , Reply# 2   12/19/2014 at 10:54 (3,409 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 799797 , Reply# 4   12/19/2014 at 13:41 (3,409 days old) by rp2813 (Sannazay)   |   | |
I've never bothered to shut off the water supply between washer uses. If the valves were more conveniently located, I might.
When we remodeled the bathroom adjacent to our laundry room, the large utility sink next to the washer had to be changed out for a slightly smaller one. The supply valves for the washer are located under that sink, and they were replaced with new ones that operate like ball valves. 1/4 turn is all it takes to open or close them. I have a feeling that they'd be more likely to operate after 23 years than the typical screw type with a neoprene washer.
This might be a good time for you to consider replacing the valves, since it sounds like you're going to have to shut the whole house water supply off when it comes time to disconnect the washer anyway. I'm not 100% sure of this, but I think the ball valve types have triangular knobs as opposed to the oval shape found on the old-school variety. |
Post# 799840 , Reply# 5   12/19/2014 at 22:06 (3,409 days old) by Yogitunes (New Jersey)   |   | |
well, valves like hoses, there are pros and cons....
I had the anti flood hose on the dishwasher....it was a 1/4 ball valve, which cracked open, dripped water into the basement, and dripped off onto the projection tv.....a lot good that hose did at that point....but it can happen at any location or setup.... probably the thing to think about is how much damage would be done should a leak of any sort happen....cabinets, floors, walls, etc....if your home, only a few gallons can have you pulling your hair out, imagine if your away and return to a lake..... most home owners policies will cover the damage, but not what caused it..... now, think further, if you rent, there goes your security deposit should a machine fail, even if a hose inside fails.....I am a big fan of renters insurance, my landlord never raised my rent for the 5 years I lived there, as long as provided a paid policy every year...I was the first tenant that ever provided him with one.... an ounce of prevention can go a long way...... |
Post# 799855 , Reply# 7   12/20/2014 at 00:04 (3,409 days old) by MattL (Flushing, MI)   |   | |
Comes down to your choice... Mine is to ignore the valves and leave then on all the time. Never had an issue. |
Post# 799858 , Reply# 8   12/20/2014 at 00:56 (3,409 days old) by ronhic (Canberra, Australia)   |   | |
There's little point turning off the taps if you don't take the pressure out of the hoses and off the inlet solenoids.
I don't do this with the Beko, but used to with my older Hoover front loader.
- turn taps off - turn programmer to next cycle that will take in hot/cold water (or cold only if cold connect) - start the empty machine as if you were going to run it - you should hear a 'thunk shhh' and a few drops of water come into the detergent drawer etc. - turn off - turn programmer back to 'off' - open door/lid
Doing this takes all the pressure off the hose and inlet solenoid and with the way machines are being made down to a price, it could well save you a flood.
Post# 799995 , Reply# 10   12/21/2014 at 00:52 (3,408 days old) by ronhic (Canberra, Australia)   |   | |
No, not at all.
If you don't take the pressure out of the line, all you have done is created 2 zones at the same pressure.
So, if your pressure is at 100lb and you turn the tap off, on the mains side of the tap it's 100lb....but because the hose to the washer was previously subject to the same pressure before you turned the tap off, it too is at 100lb.
Try it. Turn the tap off and try and squeeze the hose to the washer. It'll be hard as rock.
Now follow the process I mentioned in my previous post until you hear the 'thunk shhh' (which takes about 1 second). Now try and squeeze the hose to the washer. It should be more pliable as the pressure has been released.
You can also try this with a garden hose. Turn the nozzle off hard and the tap on full. See if you can squeeze the hose together. Now turn the tap off and then open the nozzle....some water will come out, the hose will go limp and you can squeeze the hose together. |
Post# 800009 , Reply# 11   12/21/2014 at 05:27 (3,407 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Now, you are right, if you do not remove the pressure of the hoses, they break just as commonly. BUT if they break, only the small amount of water in the hose can leak out. And on a rarely breaking 10$ item, personally, I wouldn't waste this amount of time with this procedure, minding all modern lock&sense washers... |
Post# 800012 , Reply# 12   12/21/2014 at 06:01 (3,407 days old) by ronhic (Canberra, Australia)   |   | |
My mothers ASEA was one that was made before the fitting of PEX inlet hoses. I'm here to tell you that the hot water hose blew out of the connection on the back of the machine.
She had to cover herself with 3 blankets in order to get in the laundry door and walk the 4 feet to the tap all the while being sprayed with 70c water from the inlet hose that was behaving like a stung cobra.
.....if only she'd listened. |
Post# 800066 , Reply# 13   12/21/2014 at 11:42 (3,407 days old) by kb0nes (Burnsville, MN)   |   | |
Part of your decision to shut off the valves may hinge on where your laundry is installed. On a finished upper level vs an unfinished basement with a floor drain etc.
Personally I have never, and likely will never shut off the valves to my washer. But bear in mind my washer sits in an unfinished basement with a floor drain a foot or two away. I figure if the hoses are just cared for properly, its extremely unlikely a problem will ever happen. I do still have some water damage paranoia though. Anytime I leave the house on its own for more then a day or so, I do throw the main water shut off valve. My biggest fear is having a water heater rupture, which I have had happen. I've never had a problem with a washer hose. |
Post# 800800 , Reply# 15   12/25/2014 at 02:13 (3,403 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Much like when you watched the movies in driver's ed. "that won't happen to me."
Now when we leave on vacation of something, I always shut the main water off in case a pipe burst, but I have Never turned off the washer valves.
Well tonight, Christmas Eve, company over, Chicken and Noodles on the table. Just as we were sitting down, I thought to myself, well actually bladdert said I had to go to the restroom before sitting to dinner. Just as I started to the bathroom I hear POP-WOOSHHHHHHHHHHHH. The hose, actually not the one to the washer, but the one to the dryer burst. When I got downstairs I couldn't turn the valve so I had to turn off the main. Then spent about an hour sucking up water (good ole Bissell Big Green Clean Machine)
I promise as God as my witness, after I am able to get to Lowe's on Friday, I will never leave the water on the washer again.
Thinking to self--What if I hadn't been home? Holy crap do you know all my vacuums down there that would be damaged. Never, Never, NEVER will I leave the water on, lesson learned.
Here it is now after 2:00, dishes done, presents wrapped, yes I procrastinate. Basement floor drying. Why would someone put carpet over the floor drain? It was a mess, but oh lordy what a mess it could have been.
Came back to add. These were not old hoses. They were installed when the washer was new, so five years and three months ago. |
Post# 800806 , Reply# 16   12/25/2014 at 03:54 (3,403 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Nothing is totally safe. Ever had the metal flex hose to your toilet let go? Last apartment, early morning, thought neighbor was showering but no, a little loud for that. Trundled to the bathroom and splashed into a half inch of water. Like above, if I hadn't been home I would have returned to water cascading out the front door. Do you turn your toilet off when you're not using it? Thought not.
Speaking of metal flex hose, in previous house had the one under the back bedroom sink start spraying. Also caught that before bad things happened. You spoze the Romans had these problems? BTW, if you turn off the main for vacation etc, also turn off the water heater. Water heaters behave VERY badly if they manage to siphon empty while still heating. |
Post# 800818 , Reply# 18   12/25/2014 at 08:20 (3,403 days old) by DADoES (TX, U.S. of A.)   |   | |
Some years ago I had a toilet fill tube crack below the float valve inside the tank as I was walking out the door to work. Water was spewing up against the tank lid and running out. I heard an odd noise coming from that direction so very luckily caught it before serious trouble occurred. No tragedies with washer hoses thus far. However, picking up one from one of the neighbor's rent houses for a repair, found the hot hose had an unhealthy tumor. The machines are in a hall closet between the kitchen and master bedroom ... potential for some serious damage to the wood laminate flooring. I have turned off my washer in my laundry room on a few occasions but not as matter of habit, which needs to change. Typical time between laundry runs is more than a week so turning it off isn't a serious inconvenience. I do always turn off the two or three machines in my master bathroom that run off the tub faucet. Dishwashers and refrigerators that aren't connected via copper line are also a point to consider ... but those appliances are used on a daily+ basis. Last time I left for a few days road-trip, I turned off the house main at the tank. |
Post# 800822 , Reply# 19   12/25/2014 at 10:04 (3,403 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
When I turn off the main, I turn the water heater to pilot, and turn off the ice maker.
The hose that burst last night was the rubber hose that goes to the steam dryer. The two supplies to the washer are actually braided stainless steel.
The carpet is still drying, kid has opened all her gifts, grandma is watching her Im going back to bed.
Post# 801082 , Reply# 20   12/27/2014 at 14:38 (3,401 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
I was able to get help pulling out the dryer today and changed all the hoses on the washer and dryer just to be safe.
Turned out that the rubber part of the hose was not what failed, it was actually the brass connector where it mated to the Y. I have now moved the Y to the faucet itself and installed industrial braided stainless steel hoses on everything.
As an added bonus last night, I heard a funny noise when the ejector pump kicked on, looked over and it was shooting water out the rubber boot connecting the check valve. Can't buy just the boot, had to buy a whole new check valve kit. But we can't have a sewage ejector shooting raw sewage all over the basement.
With the new hoses (2) sets to get three hoses and the new check valve spent over $100 at Lowe's last night. I will call it cheep insurance if it prevents this from happening again. |
Post# 801269 , Reply# 21   12/28/2014 at 16:22 (3,400 days old) by jerrod6 (Southeastern Pennsylvania)   |   | |
Yeah I turn off my faucets after I do the last load of clothes. My laundry is in the basement which has a drain in the floor, but I still turn the water off...and I never leave the house while the washer, dryer or DW is running. |
Post# 801291 , Reply# 22   12/28/2014 at 18:42 (3,400 days old) by Yogitunes (New Jersey)   |   | |
Harley....
they do sell the rubber boots by themselves, and a better protection for high pressure uses, they have them with a flexible metal outter covering.... but for best protection all the way around, and will save money in the long run.....install a brass check valve, with the addition of two fittings and glue, somewhat permanently in place......I actually have two check valves in the run, and a ball cutoff for service needs..... I had both rubber styles pop off...fortunately it was only from wash water......once brass in place, never an issue ever again.....been there!!! I can post some pics if it helps.... an ounce of prevention..... |
Post# 801313 , Reply# 23   12/28/2014 at 20:52 (3,400 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
The red one pictured is the check valve with rubber boot that failed. The new one is all black, this one was in place when I bought the house in 2007, and I think it had been there since the new pump was installed somewhere around 2002, so It didn't do too badly. I honestly didn't think it was a bad idea to change the check valve since I had it apart anyway.
Finally got the carpet dried, cleaned it twice with the steam cleaner, and then put a fan on it overnight. I then dry captured it this afternoon, and no more smelling like sour poo. What a Merry Christmas it was. Again I praise Jesus that we were home when the hose gave way and it only spewed for maybe two minutes.
