Thread Number: 57709
Kenmore Limited Edition Washer Console Light Is Out |
Post# 801257   12/28/2014 at 14:47 (3,404 days old) by philcobendixduo (San Jose)   |   | |
The fluorescent console light on my 1987 Kenmore Limited Edition Electronic control washer stopped working several months ago. I purchased a replacement fluorescent tube online and installed it but the light is still not working. I suspect that perhaps the starter may be bad but have no idea how to go about replacing it or where to obtain it since the washer is 27 years old. Any help from "the experts" out there would be appreciated so I can once again do my wash by the light of the Kenmore's lamp. Thanks!
Post# 801292 , Reply# 1   12/28/2014 at 18:48 (3,403 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 801314 , Reply# 2   12/28/2014 at 20:53 (3,403 days old) by philcobendixduo (San Jose)   |   | |
Post# 801340 , Reply# 3   12/28/2014 at 23:46 (3,403 days old) by rp2813 (Sannazay)   |   | |
Post# 801345 , Reply# 4   12/29/2014 at 00:41 (3,403 days old) by MattL (Flushing, MI)   |   | |
All the starters I've seen on machines are located on the back of the unit... |
Post# 801351 , Reply# 5   12/29/2014 at 02:31 (3,403 days old) by PhilR (Quebec Canada)   |   | |
Once you find it, look at the number on the starter or bring it to the hardware store as there are a few different models. Sometimes, the correct replacement they havein stock might be different-looking or made of plastic instead of aluminum but don't go by the looks, go by the number!
The starter could be visible at the back (I think they are often visible on Whirlpool machines) but sometimes, they're hidden behind the back covers. You're looking for that: www.google.com/searchQUESTIONMARK... Unless the machine has a ballast that doesn't require a starter... CLICK HERE TO GO TO PhilR's LINK |
Post# 801364 , Reply# 6   12/29/2014 at 05:58 (3,403 days old) by countryford (Austin, MN)   |   | |
Post# 801438 , Reply# 7   12/29/2014 at 14:02 (3,403 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
It's most certainly the starter, unless it's a cut wire.. starters differs in size, material etc..but thet type they were the type they remains, so just go by size and number, bring it with you.... both if it's from the 60s or the 2000 that doesn't make a little bit of difference, i have seen metal, transparent, white...what matter is size and datas, they're made just like they were and still made, I doubt they made a specific starter just for that machine..in any case you can modify it to use another one...
Post# 801460 , Reply# 8   12/29/2014 at 18:19 (3,402 days old) by philcobendixduo (San Jose)   |   | |
....and indeed it IS on the back of the console. I just gave it a push/twist and out it came!
It's marked "Sylvania Robot Cop" 20W FS-2NA Automatic Reset Starter Costa Rica UL Listed Certified ANSI Std. C 78.180 with condenser. Now, to go hunting for the replacement! Thanks for all the advice fellow AW members! |
Post# 801461 , Reply# 9   12/29/2014 at 18:26 (3,402 days old) by philcobendixduo (San Jose)   |   | |
Post# 801465 , Reply# 10   12/29/2014 at 18:35 (3,402 days old) by rp2813 (Sannazay)   |   | |
The designation may just be the difference between automatic reset and manual. Most of the starters on my garage lamps have manual resets, with a tiny push-button in the center of the top surface.
You might still be able to find starters at ACE. I've given up on OSH stocking anything out of the ordinary.
Post# 801466 , Reply# 11   12/29/2014 at 18:43 (3,402 days old) by philcobendixduo (San Jose)   |   | |
....I took the starter from the dryer and tried it on the washer and it works fine so I'll just find 2 new starters now. Yes - I suspect the "NA" designation is for the automatic reset as there is just a hole in the top of the starter housing and no button. I'll order up the 2 pack from Amazon (GE brand made in Taiwan) and give them a try. Thanks again, everyone!
Post# 801469 , Reply# 12   12/29/2014 at 19:20 (3,402 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Yes FS-2 is the type.....i don't even think they make them non-automatic anymore..
Now not sure....but I really wouldn't pay shipping for some starters, they can be found anywhere..... Here they are sold in supermarkets, convenient stores, corner stores... I just got two one week ago from the chinese store, it's 80 cents each...they had them in all kinds and wattages..mine were S-10. Extra Star chinese brand... made in prc..taiwan or china...the same...unless you want to buy GE..but there are made... They are generally available in all the kinds...the kind you look for looks to be the one with the capacitor in it...the FS-2 ...and can be replaced by the FS-U which are the universal that replaces them along with others FS kind (U stands for it)...you can go with a starter made for higher wattages as well...the universal ones are generally made to work from 4 watts to 30 and even more...all relies in the neone tube...if they worked with a 20 watt then you should be fine with whatever starter rated above 20 watts at max..just don't use a 20 watt max rated starter for a 80 watt tube... The local hardware store sure has them ..I'd not really wait and pay shipping.. This post was last edited 12/29/2014 at 19:49 |
Post# 801481 , Reply# 13   12/29/2014 at 20:19 (3,402 days old) by philcobendixduo (San Jose)   |   | |
Post# 801500 , Reply# 14   12/29/2014 at 21:28 (3,402 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Well...not having to pay shipping is very good.and makes it sure worth it then..
I am in town more than once a day, I live in a small town and i go to the store every day for a thing or another... and even in these periods there's not a long line at all, especially on few items cashes... then it takes anyway one minute for me to get to the center and buy one at the chinese bazaar...but this is me, i'd rather get it myself, but we all have different habits and we live in different locations....etc... In your case i'd do the same then... Hope you'll get your lights working soon..I so love lighted consoles..i wish I could... |
Post# 801770 , Reply# 15   12/31/2014 at 20:53 (3,400 days old) by philcobendixduo (San Jose)   |   | |
Post# 801773 , Reply# 16   12/31/2014 at 21:06 (3,400 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
