Thread Number: 57711
maytag lat9800 transmission rebuild or not |
Post# 801324 , Reply# 2   12/28/2014 at 21:46 (3,403 days old) by washee ()   |   | |
ok, thanks but where am I going to find an almond or bisque colored one to match the dryer.....? Not in boondocks......Los Angeles area... |
Post# 801349 , Reply# 4   12/29/2014 at 02:22 (3,403 days old) by beekeyknee (Columbia, MO)   |   | |
That depends on a lot of variables. You haven't given us much information. What's the over all condition of the machine, did you like the machine, is it part of a matched set, are you handy mechanically, do you like the orbital drive (short, fast stroke machines) or would you rather have the Pitman type transmission (older, long slow stroke machine), do you have time to rebuild a machine (big variable) or do you need something right away? These are only some of the variables. We can't give you a comprehensive answer to a wide open question like that and it sounds like you have some decisions to make before any questions can really be answered. In a nut shell, so to speak, we don't know your "life situation".
Post# 801354 , Reply# 5   12/29/2014 at 03:30 (3,403 days old) by redcarpetdrew (Fairfield, CA)   |   | |
There's not a lot of info here yet. What exactly went wrong with the transmission? You mentioned seals. If you're just experiencing a oil leak underneath, then the lower seal on your washer (if it's an orbital) can be replaced for a substantially reduced cost compared to replacing the whole transmission. Can you be more exact?
RCD |
Post# 801569 , Reply# 7   12/30/2014 at 14:31 (3,401 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Ok. It does indeed sound like you have a transmission issue. You can get the transmissions new and used. You can look on Craigslist or the like or try a store that hauls old ones away as part of the sale for a donor that is the same era and capacity as yours and there you go. I have a thread on here that explains how to get to it. If you are mechanically inclined, then you should be able to do it.
RCD |
Post# 802456 , Reply# 9   1/5/2015 at 16:50 (3,395 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 802613 , Reply# 10   1/6/2015 at 15:45 (3,394 days old) by washee ()   |   | |
Does anyone know if I can use a 6-2097790 replacment part for the transmission instead of the 6-2097750. Is the difference just the seals in the kit? |
Post# 802732 , Reply# 11   1/7/2015 at 03:14 (3,394 days old) by beekeyknee (Columbia, MO)   |   | |
No, the mounting stem and boot seal are the same. The difference is the ---90 is for a standard capacity and the ---50 is for a large capacity machine. Why aren't you giving us the whole model number? There should be three letters following the LAT9800.
Be careful when banging on the spanner nut down inside the tub as to not hit the side and chip the porcelain. This post was last edited 01/07/2015 at 05:10 |
Post# 802737 , Reply# 12   1/7/2015 at 05:35 (3,394 days old) by washee ()   |   | |
LAT9800AAL ...will I be able to use the kit ending in a 90 instead of the 50.....:) |
Post# 802822 , Reply# 13   1/7/2015 at 18:01 (3,393 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 802868 , Reply# 14   1/7/2015 at 23:34 (3,393 days old) by beekeyknee (Columbia, MO)   |   | |
Here. Some exploded views. I have an orbital transmission you can have for the cost of shipping. I also have the agitator that goes with it. If you're determined to do this rebuild I can give you some links. I'd suggest posting some pics so we can see what you're doing.
CLICK HERE TO GO TO beekeyknee's LINK |
Post# 816862 , Reply# 16   4/1/2015 at 09:30 (3,309 days old) by brucelucenta ()   |   | |
Get a new machine and join the 21st century. |
Post# 816971 , Reply# 17   4/1/2015 at 19:03 (3,309 days old) by beekeyknee (Columbia, MO)   |   | |
If you're looking at the end of the drive shaft where the pulley attaches (the helix) you should turn it counter-clockwise for agitate. It will, however, turn the agitator drive shaft either direction you turn it. When installed the pulley turns the shaft CCW (looking at the shaft from the bottom) during agitation and during spin the pulley climes the helix, pushes against the underneath side of the brake to disengage it and allows the transmission to spin CW when viewed from the bottom. This makes the tub spin CCW when viewing the machine from above as in normal operating conditions.
Post# 817643 , Reply# 19   4/5/2015 at 19:34 (3,305 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 817650 , Reply# 20   4/5/2015 at 20:05 (3,305 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 818006 , Reply# 21   4/7/2015 at 20:56 (3,303 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 875184 , Reply# 23   3/31/2016 at 20:50 (2,944 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 875299 , Reply# 24   4/2/2016 at 03:47 (2,943 days old) by washee ()   |   | |
Ok,the only videos I have seen take the tub out. Where do you get info on how to repair the transmission in the washer...thanks.... |
Post# 875599 , Reply# 25   4/4/2016 at 12:32 (2,940 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
You flip the washer onto its back and remove the front panel. Spin the main pulley so the inner tub spins around until the transmission has come to a stop with the flat front cover plate facing the front of the washer (up). You can then remove the cover plate without spilling all of the oil. Put some rags down inside the cabinet in case some oil spills anyway.
Good luck! Dave |
Post# 968126 , Reply# 26   11/15/2017 at 15:09 (2,350 days old) by webco (Santa Monica)   |   | |
My transmission went out on my Maytag A 806 washer. The part is discontinued (#10172457). Anybody know where I might find one? |
