Thread Number: 57721
Test Mode for new duets? |
Post# 801422   12/29/2014 at 12:30 (3,397 days old) by washerdude (Canada )   |   | |
Does anyone know how to put the washer into test mode? And how do you do it? Our model is the WFW72HEDW |
Post# 801436 , Reply# 1   12/29/2014 at 13:52 (3,397 days old) by redcarpetdrew (Fairfield, CA)   |   | |
The mini manual for this machine is hidden inside under the top. If you remove the 2-3 screws that hold the top panel on at the back then remove it, you'll see it. This manual has everything from diagnostic cycles to a list of the fault codes that either are already in the memory or will show during diagnostics.
RCD |
