Thread Number: 57794
/ Tag: Twin-Tub Washers
Hoover twin tub washer help |
Post# 802392 , Reply# 2   1/5/2015 at 11:18 (3,398 days old) by macboy91si (Frankfort, KY)   |   | |
Hi, unfortunately there are not an abundance of parts for these machines. If I were you, I would assess what it actualy needs to work as opposed to trying to buy every part you can find to restore this. The only real failure point on these machines really is the pump assuming the machine has not been abused in other ways.
More info of your machine would however be helpful, a model number at least, even better a photo or 2. Do you know anything about it's operational status? Tim |
Post# 802725 , Reply# 4   1/7/2015 at 00:54 (3,396 days old) by electroluxxxx (Syracuse NY)   |   | |
Oh and everything on it is stock as far as I know except for the pump and pump belt |
Post# 802756 , Reply# 5   1/7/2015 at 09:07 (3,396 days old) by macboy91si (Frankfort, KY)   |   | |
That rubber is pretty tough, but it can break. In my experience it always looks like hell (dry-rotted looking) but I have never had one fail. As far as sources for this part in the US, there are none that I am aware of, someone on the other side of the pond may have a good used one, but that would be the only way to obtain one that I could think of. You could however probably do a pretty decent repair with RTV silicone sealant of it if is simply a crack or pinhole leak. I just checked my 74, it looks flaky but it's still fine.
Tim |
Post# 803551 , Reply# 6   1/11/2015 at 23:47 (3,391 days old) by electroluxxxx (Syracuse NY)   |   | |
Tim I know I am a little delayed but here are some photos of the washer and matching dryer! |
Post# 803580 , Reply# 7   1/12/2015 at 07:20 (3,391 days old) by macboy91si (Frankfort, KY)   |   | |
I think it looks normal, this is a Hoover 0510, so it's a mid-60's machine. This machine has a bigger flywheel/pulley than the newer ones, makes for a more balanced spin cycle ("balanced").
I think you're fine, you could periodically check it time to time, but I would expect it to look the same. Hand-warm water in the spinner if you spin-rinse will soften it some during use. -Tim |
Post# 803669 , Reply# 8   1/12/2015 at 15:34 (3,390 days old) by electroluxxxx (Syracuse NY)   |   | |
Thanks so much for your input!! I will keep an eye on it :). Bill it would be awesome to get in touch sometime! |
