Thread Number: 58014
Question concerning injector hose for mid 80's Maytag A512 |
Post# 804863   1/19/2015 at 10:02 (3,383 days old) by ken (NYS)   |   | |
Picked up a mid 80's (brown console/buttons) Maytag A512 washer and D512 dryer over the weekend. Washer works fine except I noticed a water leak running down the outside of the outer tub when filling. After researching here I see its probably the injector hose. But Im not sure which hose I need. I checked on easyapplianceparts and found two different injector hoses. One is a curved all rubber assembly with the flange end. The other style is a longer rubber hose that attaches to a plastic flange fitting that uses a rubber washer.
www.easyapplianceparts.com/PartIn... www.easyapplianceparts.com/Schema... Replacement on ebay but A512 is not listed as a model it fits. http://www.ebay.com/itm/Washing-Machine-... |
Post# 804865 , Reply# 1   1/19/2015 at 11:00 (3,383 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
More often than not, it's the injector valve that's leaking. See link below. CLICK HERE TO GO TO kenwashesmonday's LINK |
Post# 804868 , Reply# 2   1/19/2015 at 11:34 (3,383 days old) by Yogitunes (New Jersey)   |   | |
better to note exactly where the water is coming from, could be a hose, injector assembly, or even a rusted clamp that came off......injector assembly may be hard to find, several times I have replaced it with a piece of plastic pipe, minutes later, back in action...
don't rule out the outter tub seal leaking or the tub itself having a pin hole.....I had one like this, took forever to pin point where the water was coming from... |
Post# 804869 , Reply# 3   1/19/2015 at 11:40 (3,383 days old) by ken (NYS)   |   | |
Thanks for the info. This is my first experience with a Maytag. I got the w/d for a friend and they are at his place. I'll need to stop over there and get the top off to see exactly where the leak is coming from.
Now that I see the Maytag setup Im curious why they had that injector assembly and not just a continuous hose? What purpose did the injector serve? I see that models after the center dials had an open cup as part of the assembly that can over-fill and the water just spills over the side. |
