Thread Number: 58015
stuck Penta-Vane agitator on Kenmore washer |
Post# 804867 , Reply# 1   1/19/2015 at 11:10 (3,383 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi John, you can try slowly pooring a gallon or two of boiling water over the top of the agitator and then pulling it off, but you may need to use and agitator puller to get off.
The slipping during agitation is most likley a transmission problem, likely caused by water in the transmission, if so the washer needs a heavy rebuild if you want to get much more use out of it. You can contact me with your phone# if you want more details of what needs to be done. John L. |
