Thread Number: 58050
/ Tag: Modern Dryers
My wierd semi commercial dryer. Questions |
Post# 805294   1/22/2015 at 05:38 (3,381 days old) by Ilovewindex (Tualitan OR)   |   | |
I have a "Unimac" non coin operated semi commercial dryer. Bought it from a tweaker bout 2 years ago who clamied his ex wife had bought it through a supply catolog at her job. I did some reading and assume its a Speed Queen built dryer. My question.. should i upgrade to the fancy new speed queen washer or should i just keep it. Also will it be harder to get repairs and such on it because ots not an actual speed queen?
Post# 805529 , Reply# 1   1/23/2015 at 15:20 (3,379 days old) by jkbff (Happy Rock, ND)   |   | |
Post# 805532 , Reply# 2   1/23/2015 at 16:08 (3,379 days old) by Mrb627 (Buford, GA)   |   | |
Post# 805547 , Reply# 3   1/23/2015 at 17:22 (3,379 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Yes, I assume it was a typo and you meant dryer?
Dryers are simple things in the mechanics, whether commercial "normal size" like the ones of this kind, new or old or "fancy" they works pretty much the same way... I see this one has a timer drying, not automatic sensing "auto cycles", so is without thermostats who detects when laundry is dried by hotness level..but you've to set what you find to be the proper time according to load quantity and type (just matter of getting used to), the "fancy" (supposing you meant the electronic) speed queen IIRC did put moisture sensors instead of thermical which if correctly working makes sure that machine will shut off a little bit more precisely than heat sensing, heat sensing may result them in running a little bit longer than actually needed for certain loads ...but not that Big deal IMO..moisture sensors are around from ages anyway. Uni.macs are speed queen made and as they claim they use about the same parts both for domestic and commercial machines, with a few differences I noticed but not big ones.. then surely parts seems still available and if I may say you can find parts for dryers even older than this.. Whether made from Raytheon or alliance Speed queen I see parts are plentily available for the dryers...I have raytheon made speed queen set and can find pretty much all the parts in stock, even because at that time of raytheon made speed queens many other brands such as Amana and Maytag shared parts...as Amana was bought by raytheon, who sold to global Goodman something who sold it to Maytag..... Uni macs are good dryers, if it works I don't see why you should change it if you're not bothered by time drying, unless you want a specific dryer looking differently for mere aesthethic reasons, then that's another matter... Remember also uni-macs and alliance aka commercial speed queens are sold all over the world, if there has to be a large stock for parts it's for them... This post was last edited 01/23/2015 at 18:34 |
Post# 805914 , Reply# 5   1/25/2015 at 09:44 (3,378 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Tom: Yes, no special thermostat except cycle one, but they do work thanks to detection and combination of dryness and hotness, please correct me if I'm wronmg, but from what I knew they used this principle:
That's because is an indirect cause, as a load tend to gets more dry, the more dry it gets the hotter it gets and in a shorter/quicker time, hence the sooner and more often the cycle thermostat sense it got hot and cycles off burner/element the sooner and more often the timer will advance to the end of cycle, wet laundry will take more to get hot and take less getting cool and the opposite happens as it gets dry...this mechanism allows the machine to go by dryness level thanks to the combination of hotness of laundry and "technical" times. In a time set drying cycle, heater/burner will still cycle off and on to mantain selected temperature, but it will not stop until the timer has finished indipendently from what the thermostat do.... Anyway yes, as I also said a time setting is really all matter of getting used to, as long as you learn how much your dryer takes for a certain load it'll become "automatic" for you to iamgine how much it'll take for all the various ones...is a very quick thing to learn... This post was last edited 01/25/2015 at 10:08 |
