Thread Number: 58052
/ Tag: Modern Dryers
New Dryer - Miele T8722 |
Post# 805343 , Reply# 5   1/22/2015 at 12:27 (3,374 days old) by logixx (Germany)   |   | |
The problem with using mains water would be that it would eventually clog up the condenser with lime scale. The condensate, as you've said, is destilled water that won't cause those problems.
I have used a bunch of condenser dryers in the past and all had fluff residue in the water tank - so it's not just something that happens on the selfCleaning BSH machines, which, by the way, we revised several times since they were first launched.
With that being said, in an ideal world, I'd love a Miele vented dryer - but we have no way to vent and Miele pretty much stopped building them, as there's only one lonely model left on Miele's homepage. :-( |
Post# 805367 , Reply# 7   1/22/2015 at 14:54 (3,374 days old) by logixx (Germany)   |   | |
Post# 805466 , Reply# 12   1/23/2015 at 07:41 (3,373 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
The PerfectDry adapts, but only to a certain degree. If the resitance is to low, underdrying can occur. If you do not have underdrying, you should be fine without adjusting! |
Post# 805474 , Reply# 13   1/23/2015 at 08:31 (3,373 days old) by northernmary (Huddersfield - West Yorkshire)   |   | |
Hello All,
I’ve got the condenser version of your vented machine, I love it, my t8822c (Energy rating B) dry’s even and no fuss when it comes to tangled up bedding, the perfectdry has always been spot on never under dry or over dry I’ve always found it to be effective, clean the condenser and wash the filters the first of every month religiously just to keep the machine running as efficient as possible. An 8kg wash load from the WKF120 normally takes around 70 mins dried on cottons normal + low temperature (all my washing gets dried on low temperature) I’ve had the machine now for a while I wouldn’t change it for anything I’ve contemplated purchasing the matching T1 machine but I just cannot justify it as I’ve got a perfectly good machine with 10 years parts and labour Northernmary |
Post# 805875 , Reply# 15   1/25/2015 at 05:12 (3,371 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
